Question about Canon IR1600 230 VOLT 50/60HZ
What do I do when my copier says incorrect paper size?
    New Friend:
Check your paper tray,,,
Posted on Dec 10, 2013
3 Suggested Answers
SOURCE: Canon iR1600 incorrect paper size problem
change te paper size reader on the front saite on copier ( or cleaning the contacts on the same reader )
Posted on Nov 27, 2010
muntejaya
  • 10421 Answers
SOURCE: Canon ImageClass D680 "Incorrect Paper Size" error message
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay kbxlz
Posted on Feb 12, 2011
Thin client printing incorrect size
Dear
Pl. go to printer setting and choose the correct paper size as per the paper used with printer. Also check the application software for paper size,margin etc.
Thanks.
Feb 26, 2015 | Office Equipment & Supplies
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
If envelope printing Canon PC-D340 All-In-One Laser Printer incorrect paper size problems.showing
You need to make sure the paper size and that of the printer matches in the dialogue box.
i.e assuming you a printing an envelop DL size, make sure your envelop is the exact size you choose in your page layout.
secondly, open the properties in the printer dialogue box, where you have letter, change the default "letter" paper to you envelop size.
Note: if your envelop size is not accurate and the actually printed, you will still receive "incorrect paper size" error. At this point I turn of mine and turn on again.
Jul 17, 2011 | Canon PC-D340 All-In-One Laser Printer
I am feeding a portrait fax letter size and it is being received partially - one half is cut off. please explain
It sounds as if the document feeder is not recognizing the proper size of paper. Try making a copy, is the copy correct or is the copier indicating to load a certain size of paper. The paper width guides as well as the raised tabs on the document feeder tell the copier the proper paper size. Could the problem be on the other end? I know I have several customers that have the paper size dials or indicators incorrect for the paper in their cassettes. This would be if only a single reciever of your fax is complaining. You may want to see if rotating the fax in the LTR-R direction works.
Dec 03, 2010 | Canon imageRUNNER 4570 Copier
A fax was coming through and stopped. The fax
change the orientation of the paper supply and or size.. portrate or land scape.. check your printer settings in your display on the paper supply size and type
Mar 31, 2010 | Canon LaserCLASS 510 Printer
Portrait v. landscape
Check the paper size dial on the paper drawer. Most likely it is incorrectly set - either size, and/or orientation.
Jul 06, 2009 | Ricoh Aficio 2015 Copier
Printer keeps printing garbage
i believe that if you update the firmware for the copier, you shoud see that the garbage printing should go away.
Mar 31, 2009 | Minolta DiALTA Di183 Copier
My printer display incorrect paper size and stop printing
Try checking that the paper size settings in your printer driver ar set to either 'AUTO' or to the paper size that is being fed thru the printer. Let me know?
Nov 22, 2007 | Canon imageCLASS D320 Digital Copier
Canon IR1600 230 VOLT 50/60HZ Logo
42 people viewed this question
old marine
old marine
