Hoover easy logic error message number 3 model is a EL 160
Error message 3 keeps coming up any ideas ?
  • karenballan Feb 01, 2009
    My machine EL160 comes up with an error message 3 towards the end of the washing cycle and the machine is not completely drained. What is this code?
  • Mark Egan May 11, 2010
    What's the message?
  • 15,935 Answers
E3 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain program.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
Thanks
Jul 26, 2012 | Maytag Washing Machines
I have a Samsung DLP, model hlp5063w. When I turn it on, the picture comes on and a few seconds it kicks off. After a few more seconds, it turns back on. It keeps turning on and off until I unplug it. Any...
2 most common causes of that sympton would be
1. Lamp failure is the most logical culprit BP96-01403a is the lamp number and I recommend only using an OEM replacement
2. Color wheel malfunction. Usually when the wheel fails you will hear a very loud motor spinning sound from within the tv.
If you havent replaced the bulb in a couple years that would be the most logical cause.
Oct 28, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
I need a replacement door for my Hoover Easy Logic 1100 aa Washing machine. I beleive that the model is discontinued but my machine is in perfectly good working order. Could you advise anywhere where I...
I searched for quite some time without success and I am Pretty good at finding things.
Contact Hoover using this link:
http://service.hoover.co.uk/spares
To order Hoover Genuine Spares & Accessories please call 08443 712758
Opening hours: Mon-Fri 8.30am - 5pm.
I could not even come up with the part number for the door. I did find the following:
1. Door Seal
2. Door Glass
3. Door Handle
4. Door Hinges
No luck on finding the complete door assembly.
Another alternative... if the Yorkshire area has an appliance recycling venter you may be able to find one there or in the classified ads "for parts only" But then your faced with disposing of the "junk."
I recommend you contact Hoover using the number or Lonk above and see what they can do for you.
I wish I could have done more for you but the whole door assembly just does not seem to be readily available.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Washing Machines
My hoover visionhd washer is making a rattly noise and keeps coming up with an error message half way through wash
i would check the filter incase there is someting stuck in the pump. would explain the rattling noise and also the error code.
Feb 16, 2011 | Hoover Washing Machines
Solucion para error 6000
Error code [6000] or light blinking 3 times.
1. Smearing or scratches on the LF encoder. Please clean the LF encoder.
2. Foreign material or paper debris in the LF drive. Please remove any foreign materials if encounter.
3. Check cable connection.
4. Replace LF encoder or Logic Board
May 27, 2010 | Canon Office Equipment & Supplies
Where can i print out a copy of the product manual?
The link for manuals is here:
Hoover Manuals
The model number you gave does not produce a manual, only an error message. Check again on the model number and insert it in the search window on that page.
May 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
No manual for Hoover Logic 1250
try here you must have your model number off the serial plate on the washer http://service.hoover.co.uk/manuals/?Section=2
Mar 12, 2008 | Washing Machines
My light bulbs keep burning out prematurely on my garage door opener.
This is a logic board issue. You can purchase a replacement one at searspartsdirect.com. Enter in your model number and a parts list will come up. This is a fairly easy install, make sure and unplug the unit first. You will have to reprogram the remotes. Thanks BB
Feb 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Hoover windtunnel
would suggest the drive belt is stretched and thus is slipping when contact is made with the carpet.
Jan 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Washing Machines Logo
136 people viewed this question
Top Washing Machines Experts
