Question about GE Spacemaker 1.7 Cu. Ft. Over-the-Range Microwave
Ge spacermaker (JVM231BL001) over the range microwave oven replaced fuse everything worked until i pressed one of the auto start buttons short out again what's causing this
MicrowaveSvc
  • 9047 Answers
SOURCE: Some buttons work, some don't.
The keypad may be bad. Most often they go bad due to moisture from cleaners being sprayed directly on them or steam from the cooktop when the vent fan is not used.
They can also go bad when the unit is stored in an unheated environment where there's a lot of air temperature change (hot during the day, cold at night, etc.)
It may also be some residue on the connections where the keypad plugs into the control board. Unplugging then replugging the keypad can sometimes clean them.
In other cases, a new keypad is needed.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Above the Cooktop Oven Microwave JVM1533 Turn table does not move
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
In this case, I would suspect the primary interlock door switch.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 12, 2008
revamos
  • 16 Answers
SOURCE: GE spacemaker no longer heats
most common problem mag tube out
Posted on Apr 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 09, 2009
Have GE built in microwave on top, oven on bottom. Microwave stopped all sudden, changed out fuse and comes back on but soon as press start button..fuse blows and unit stops..need help troubleshoot
If the unit shorts when you push start. it is something shorted in the high voltage section of the unit. The HV section is made up of 4 parts. The High voltage transformer, the Capacitor , the rectifier / diode. and the magnetron. If the mag shorts it will just hum loudly and not heat, so Your problem is probably the capacitor or a shorted transformer. More commonly it is a bad capacitor. If you have an ohm meter, check the capacitor. It should not read shorted. If it does that is your problem. If so replace the rectifier too just for good measure.
Sep 23, 2017 | GE Microwave Ovens
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE jvm230 blows fuse when the start key is pressed. Refused and all is well until start key is pressed again and the fuse blows. I think my HV cap. is shorted. The HV capaciator isreading less than 1...
It might be the cap but it is probably a bad diode. The diode if shorted to the cabinet will of course blow the fugging fuse every time. The diode should have continuity in one direction only. If the 2 leads between the mag are shorted to chassis the fuse will also blow. You have 3 suspects the diode the cap and the mag. I would replace the cheapest thing first and that would be the diode and i am correct a shitload of times. Peace brother.
Jun 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Keeps blowing fuses
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/cap_test.html
You can order Panasonic parts from Tritronics here or by calling 866-779-5835, but if you don't find what you're looking for there, try here.
Nov 07, 2008 | Panasonic NN-H275 Microwave Oven
Replacing door latch pawl
how do I replace door latches on a spacermaker XL microwave oven? thanks
Oct 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1.7 Cu. Ft. Over-the-Range Microwave Logo
205 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
