Question about Lexmark X5470 All-In-One InkJet Printer
Paper catch rollers out of alignment
Paper picks up but won't go on through the rollers - seems to be out of alignment. Tried to remove rear cover (3 screws) but it will not come off.
Bottom of paper edge just creases up and stops.All other components seem to be working fine. Have removed cartridges, unpowered machine, and tried moving a folded envelope through the rollers left to right - no joy.
  • ssranch01 Feb 13, 2009
    i have the same problem one roller works but the other one does not catch the paper. i have removed the three screws in the back but can not get the cover off to look at the rollers. what do i need to do?
Inside the printer by rollers belt fifteen inch piece like a ribbon comes out ON screen showing clear carrier JAM please help
Posted on Nov 06, 2011
  • 29 Answers
Hi.
Try this
1.take a sheet of paper ,,fold it length wise 2-3 times to make it thick.insert this into the paper feed tray...move it left and right a couple of times..this clears the obstruction if any..
if this does not work..call lexmark tech support,,,your printer would be replaced if in warranty..
good luck
Posted on Jan 25, 2009
Fi-6130z fujitsu scanner jamming repeatedly
Hello Meg,
To troubleshoot your scanner issue, yuo are advised to perform the steps provided below:
1.Remove all documents from the ADF paper chute.
2.Open the ADF while pressing down the ADF open lever. If your has the imprinter option attached, please open the imprinter and then open the ADF.
3.Remove the jammed papers from the ADF.
4.Close the ADF pushing the center part of the ADF carefully.
If document jams occur frequently, then please check the followings:
1. Do the documents satisfy paper specification?
2. Have the documents been jogged?
• Align the edge of documents for stable paper feeding.
• Remove documents with crease or dog-ear.
• Scanning different width of documents may cause skew and result in paper jam.
3. Are Chuter Unit (ADF paper chute),Guide P ASSY (Sheet guide), Feed roller cover (plate guide) and Brake roller cover installed correctly?
4. Clean the Feed rollers, Eject rollers,Plastic rollers, glass surface and paper feeding surface, and see if the error is resolved.
5. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values, replace Pick roller or Brake roller see if the error is resolved.
6. If the issue still persists, then you are recommended to contact the nearest Fujitsu service center for further assistance.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Nov 26, 2013 | Fujitsu Fi6130z Sheetfed Scanner
HP Deskjet 3745 says "out of paper" even if there
Relace the bend papers and delete the due print in printer IQ.Restart the printer and check if problem did not solve then try it----->Remove the power plug and then--->
  1. Product with one rear access door release tab Product with two rear access door release tabs c01963694.gif Illustration of removing the rear access door. c00104514.gif Product with a rear access door release knob Product with in-tray catches c01964197.gif Illustration of a product with a release knob on the rear access door c02297019.gifIllustration of in-tray catches Product with a duplexer c01964198.gif Illustration of a product with a duplexer.
  2. Wipe each paper roller with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers upward carefully to clean all the way around. Figure 1: Paper rollersc01438859.gif
and restart the pc plug in the printer.Check the status if problem persist uninstall the driver and install the driver again.If you give A4 paper,choose the paper A4 in printer setting.I hope this will be solved.
Jun 07, 2011 | HP Office Equipment & Supplies
Attempt to make a copy is stopped when "paper jam" error message comes on. The rear door opens to reveal the copy accordioned against the drum area, With every try this happens. Can it be...
It sounds like the rollers are not feeding the paper properly. It's likely supposed to go up and around to be printed on, but the upper rollers are not catching the paper properly and instead of feeding through like it's supposed to, it's crunching up against the drum.
The rollers in a laser printer can sometimes get dirty and won't pick up the paper properly. My recommendation would be the following:
1) Remove the paper from the printer.
2) Open the back cover.
3) Take a damp, lint-free cloth (add a couple drops of vinegar to it for extra cleaning power) and hold it lightly against the rubber rollers inside the back of the printer.
4) Tell the printer to make a copy so that the rollers will try to move to pull the paper through.
The rollers should essentially clean themselves against the cloth as they try to move to prime themselves. You might have to repeat the copy request a couple of times in order to get them completely clean.
If this solution doesn't work, you could try taking it into a repair shop, but it's likely that repairing a printer is going to cost more than simply buying a new one, unfortunately.
Hope this is helpful!
May 08, 2011 | Brother DCP-7020 All-In-One Laser Printer
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
Paper is repeatedly jamming in rear to point of not working or coming out extremely "wavy". Have wiped down pick up rollers. Suggestions?
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Feb 11, 2011 | Brother MFC 7420 All-In-One Laser Printer
HP Officejet Pro LP 7880 feeder does not work, how to fix it?
Step one: Check the paper in the ADF The condition of the paper or the amount of paper loaded in the ADF might prevent the ADF from picking it up and feeding it through the product.
  1. Make sure that no more than 50 sheets of paper are in the ADF input tray.
  2. Make sure the original is not photo paper or carbon paper. These types of originals must be loaded on the scanner glass.
  3. Make sure the original document that is loaded in the ADF meets the following criteria:
    • Free from curls, folds, creases, and tears
    • Does not have staples or clips attached
Step two: Make sure the ADF pick assembly is in good working condition
  1. Remove the document feeder and open the ADF cover.
  2. While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
  3. Examine the pick assembly.
    • Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
    • Make sure the stack stopper, which is located between the top and bottom rollers, fits within the double slots just above the bottom roller. The stack stopper should move freely within the double slots to flow up and down when the whole pick assembly is lifted and lowered into position.
  4. Return the pick assembly to its original position.
  5. When the product is turned on, the top roller will reset to its original position above the separator pad. There will be a gap between the separator pad and the top roller.
  6. If there is no gap between the ADF top roller and the separator pad, press the Power button to turn off the product.
  7. Wait three to five seconds and then press the Power button to turn the product on. The ADF rollers should reset to the correct positions.
  8. Close the ADF cover and replace the document feeder.
Step three: Clean the rollers and separator pad
  3. Lightly dampen a clean, lint-free cloth with distilled water, and then squeeze any excess liquid from it.
  4. Use the damp cloth to wipe any residue off the rollers and the separator pad. If the residue does not come off using distilled water, use isopropyl (rubbing) alcohol on the cloth instead.
  5. Return the pick assembly to its original position.
  6. Close the ADF cover and replace the document feeder.
Step four: Detaching and re-attaching the ADF pick roller assembly If the ADF pick assembly is detached or not connected properly, follow the steps below to resolve the issue. If the ADF pick assembly works well, do not perform these steps.
  1. Press the Power button to turn off the All-in-One.
  2. Remove the document feeder and open the ADF cover.
  3. Press the blue-green ADF-release button to release the ADF rollers from the pick assembly as shown in the figure below (the red arrow is pointing to the ADF release button).
  4. Re-attach the ADF pick rollers by placing the rollers into the roller slot of the ADF pick assembly as shown in the figure below. The red arrows show the gears on the ADF pick assembly aligned on one side. The yellow arrows point to the two-catch notch.
  5. Once the rollers are placed on the two-catch notch, push them in, so that the two-catch clicks into place. The photo below shows a correctly installed ADF pick assembly.
  6. Close the ADF assembly and cover.
  7. Turn the product on and make a copy with the ADF to check that the pick assembly works.
Jul 16, 2010 | HP Officejet Pro L7680 All-In-One Printer
Brother Laserjet 8860dn printer not picking up/feeding paper
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
HP Photosmart C6150. Rollers do not pick up paper
Remove the rear cover a reallly scrub the black rollers with isopropyl alcohol. Scrub HARD
Jun 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Paper won't load up....
Disconnect the printer from power source and computer. Remove the rear access panel and very carefully use a alcohol moistened cotton swab to clean the all the black rubber pick-up rollers. Use a gentle sideways stroke while cleaning and turn rollers to clean all sides. Allow the rollers to dry and replace the rear cover and power up. Worked wonders for me. HP has certain 3210 printers that have this problem.
Oct 25, 2007 | HP Photosmart 3210 Printer
Lexmark X5470 All-In-One InkJet Printer Logo
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
