Question about Plumb Shop Alsons #PSB2510 Chrome Adjustable Spring Shower Head
Preasure keeps rising and falling/water gets cold and hot
Triton Ope11
  • maggiegeorge Jan 25, 2009
    Sorry pressure NOT preasure
  • 33 Answers
This is a problem that should be looked at by a Pro. I don't know if you have a water heater or you are getting your hot water from a domestic coil on a boiler. "Your home heating unit" It is hard to give a solution to this problem without seeing it.
Posted on Jan 26, 2009
I have a 1993 mercury' marquis. The floor boads of the front part of the car get hot. And the thermostat keeps falling to c and rising to half way and falling on gage. Can u please help?! Thanks
possible no water in the engine and it is overheating
this is indicated by the temp gauge rising and falling
temp gauge sender units need to be immersed in water full time to get a reading so if it goes up that is in water and when it falls back that is in nothing or steam
hot engine would account for hot floor
Aug 14, 2016 | Cars & Trucks
HOT AND COLD
Sounds like you have an air lock in the heater, needs bleeding. From cold check and top up coolant, run engine without coolant cap put heater control to hot, watch the fluid level, will rise then fall suddenly when the thermostat opens, top up coolant and put the cap back on, later when the engine has cooled down again, check coolant level. Hope this helps.
Dec 20, 2013 | 2006 Hyundai Elantra
My Triton t80si shower "cycles " going hot then cold then back to desired temperature - only just started happening no problem with flow of water
It sounds like the cartridge has to be changed. Pressure balance is not working in the cartridge.
Apr 13, 2013 | Home
Why does my 1994 bmw 316 coupe temparature gauge rise and fall
that is normal when it start going into the red that is bad
Sep 18, 2012 | 1994 BMW 3 Series
I want to know the most effecient height as to wall mount my Model LRA257ST2 25,000 BTU air conditioner. Is closer to the ceiling better?
Yes, closer to the ceiling is better. As, hot air rises and cold air falls. Just keep it about a foot off the ceiling.
Apr 06, 2011 | Frigidaire Heating & Cooling
No water, hot or cold from Triton T90si. Any ideas please?
The Triton t90si is fed from the tank in your attic.This also feeds the cold water in your bathroom.If you still have cold water in the bathroom tap,it means that there is water in the attic tank so the problem is somewhere else.I believe there is a bleed valve on these showers so maybe that is the problem. It may also be that the pipes are clogged up with dirt or limescale.The water filter may need cleaning. Hope this will help with your thinking on the problem.
Dec 19, 2010 | Home
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
MY HOT AND COLD METER KEEPS RISING AND FALLING
If the fans are electric, then replace the fan control module.
If the fan is belt driven, replace the fan clutch.
There is a chance that the thermostat is failing, but if the temperature fluctyation occurs during driving, as opposed to stopped and idling, then it's probably the fans.
Dec 18, 2009 | 1998 Oldsmobile Intrigue
Plumb Shop Alsons #PSB2510 Chrome Adjustable Spring Shower Head Logo
148 people viewed this question
Top Plumb Shop Home Experts
john h
Tom Chichester
Are you a Plumb Shop Home Expert? Answer questions, earn points and help others
