Question about Gigabyte GA-7ZX Motherboard
Need a diagram of motherboard pins
I have a Gigabyte GA-7ZX motherboard, but no longer have the installation manual. i need to know what pins to connect for the power switch and reset buttons.
  • Johendra Dec 30, 2007
    I tried to upgrade RAM onto GA-7zx Motherboard. It was fine before the upgrade. I got 3 short beeps repeating over and over even before PC Starts up. I changed back to previous RAM with same result. I do not have the manual for the Board. Can you asist?
    Johan Groenewald
  • Anonymous Mar 13, 2014
    want information on 18 pin front panel connections for Gigabyte GA-8SML Motherboard
  • 624 Answers
The link below will take you directly to the GA-7ZX family page. You will have to figure out which revision/series board you have and download the appropriate manual. http://www.gigabyte.com.tw/Support/Motherboard/Manual_List.aspx?Keyword=GA-7ZX. Good luck and don't forget to rate this post.
Posted on Jul 13, 2007
I need the front panel connections location, which ones go where for the ga-73pvm-s2h motherboard
Gigabyte has the manual for the GA-73PVM-S2H on the product support site: http://www.gigabyte.com/products/product-page.aspx?pid=2691#manual . The full manual is near the bottom of the list. The direct link to the English version of the manual is http://download1.gigabyte.us/Files/Manual/motherboard_manual_ga-73pvm-s2h_e.pdf . The Motherboard Installation Guide at the top of the list is a generic manual for all motherboards.
The front panel connections are shown on page 28 of the manual. There are two lines of pins. From left to right, the inside line of pins are the Power LED +, Power LED -, Power Switch +, Power Switch -, then the Case Speaker +, Case Speaker -. (The speaker - is next to a Case Fan connector; so there are a couple of blank spots between the speaker + and - pins.) On the line of pins at the edge of the board, again from left to right: HD LED +, HD LED -, Reset Switch -, Reset Switch + . There is no contact on the last pin in this group.
I hope this helps.
Jun 06, 2016 | Gigabyte Computers & Internet
I want to know that how can I assemble my wires in GIGABYTE GA-8I945GZME-RH
Assemble wire, you must mean install the power supply cords.
1. Find the long cord called "24 Pin", the motherboards usually have that plug on the right hand side, above the SATA connectors
2. Most motherboards need a 4 or 8 pin plug in order to power the CPU, most modern power supplys have adequate connectors, should be somewhere on the rails.
3. Your case has specific wires needed to be plugged in, usually on the bottom. Follow your case instructions for this.
May 05, 2015 | Gigabyte GA-8I945GZME-RH Motherboard
Recommend me a good gigabyte mother board.
Without anymore information, what your wanting to build the computer to actually do, Gaming etc...
Have a look at the :
Gigabyte GA-P41T-ES3G G41 Socket 775 8 Channel Audio ATX Motherboard
Jun 25, 2010 | Gigabyte GA-7ZX Motherboard
I want all the pin details of motherboard diagram for GA- 8i845GV
Download the manual from Gigabyte;
http://download.gigabyte.eu/FileList/Manual/motherboard_manual_8i845gv_e.pdf
In order to view the manual you'll also need to download and install Adobe reader; http://www.adobe.com/products/reader/
With Adobe you can zoom in on any page. The manual is put together in such a way that you'll be able to connect everything. Most people have trouble connecting the, chassis front panel. Since wire colors vary from case to case you'll find each two pin jumper will share a specific wire color. Normally this common wire color is white and is used as negative.
(Except for the MB speaker). Common wire color for the speaker is, "red for positive and black for negative".
Take you're time and follow the manual.
Mike
Apr 28, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Reconnnecting wires from on my Gigabyte GA-7ZX motherboard
you can check the MB pinout diagram from their website. The powersupply connector generally of a unique size and you can easily identity by the pin numbers and safely connect it, as you cannot insert it in a wrong direction.
Nov 17, 2017 | Gigabyte GA-7ZX Motherboard
How to connect plugs of front panel in the main board?
the power switch connector goes vertically where it says pw on the pins at the bottom right of the board. there is a diagram in the user manual on page 23. you can download the manual fro their website.
Thanks
Apr 05, 2009 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
MOTHERBOARD GA-7ZX THE PROBLEM IS , I HAVE A MOTHERBOARD GA-7ZX,WITH VGA ON BOARD AND IN YOUR MANUALS , THERE IS NOTHER ABOUT THIS MODEL AS I SAID MOTHER BOARD GA-7ZX, ALL YOUR VER. IS MENTIONED THAT MODEL...
You posted this problem twice. I have replied to each differently.
The motherboard manuals would be supplied by the manufacturer, in this case a company named Gigabyte, which is not a part of nor related in any way to FixYa.com website. The following is a link to the support page for this motherboard on the Gigabyte website:)
http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1369
There are three revisions of this motherboard {1.x, 5.0 and 5.1} and NONE of them have onboard VGA. All use an add-in 4X AGP VGA card that goes into the brown slot at the top of the white PCI slots.
Compare your motherboard to the pictures available at Gigabytes' support page (the link above) to make sure we are talking about the same motherboard, although as far as I can see there was no other manufacturer that made a motherboard with the GA-7ZX designation. Please verify and repost your results.
Jan 09, 2009 | Gigabyte GA-7ZX Motherboard
THE PROBLEM IS AS FOLLOWS. MY MOTHERBOARD IS A GA-7ZX WITH VGA ON BOARD , BUT IN YOUR MANUALS , THERE IS NOTHING ABOUT THE VGA ON BOARD, AS I SAID IT'S A GA-7ZX .fFOR ALL V ER. 1, 5.0 5,1 IS MENTIONED IN...
There are three revisions of this motherboard {1.x, 5.0 and 5.1} and NONE of them have onboard VGA. All use an add-in 4X AGP VGA card that goes into the brown slot at the top of the white PCI slots. You must provide your own video card if you received the board separately (outside of a system). If you received a full system the card may already be installed. you will have to physically remove that card (with the system off and unplugged first!) and look at any writing on it to determine the manufacturer brand and model of the video card. I assume you are asking so you can locate the correct drivers for the video display. If so, please repost the information on the video card along with the operating system you are using so we can help you locate the correct driver.
Gigabyte GA-7ZX Motherboard Logo
448 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Computer Links
steyr1
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
