Question about Hoover AAA140 Front Load Washer
Stain blaster light keeps flashing
I have a candy alise gow475, it starts up a cycle but stops whenever the drum should start to turn
motor speed sensor problem u cant fix yourself .it needs a skilled technitian.
Mar 30, 2015 | Candy Washing Machines
Bottom of bowl is stained very much. Appears to be a defect in the the finish?
Try using one of these A product called Kaboom Bowel Blaster and let it sit in the bowl for a while, then brush clean. This worked for me when others failed. You can try muriatic acid as a toilet bowl cleaner.Again let it sit for a while then brush and flush available from places like Home depot.Sometimes the toilets are not glazed as well as they should be you might call it a defect I call it poor quality control.
Aug 01, 2014 | American Standard Home
How to stain wood veneer
You would need a stain that would penetrate the wood veneer. A good oil based stain should be able to penetrate all the way through. Lightly sand the face of the veneer with 220 grit or higher sand paper. I use a sanding block made out of rigid foam and sand by hand. You will need to keep the veneer wet with the stain until it penetrates. I would stain both sides of the veneer until it penetrates to the depth you desire and then wipe off any remaining stain. You may need to press the veneer until it dries thoroughly! Good luck.
Mar 21, 2014 | Crafts & Hobbies
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
Candy Alise-the stain blaster and 90 degree lights are flashing and it will not function. Please help!
Hi again,
11 flashes decodes as 'faulty dryer module or wiring to it'. Not sure that helps you other than saying that a service call is required, sorry ;-0(
Good luck,
John C
Mar 22, 2011 | Washing Machines
Could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Dec 10, 2009 | Candy Washing Machines
Creative blaster problem..
mmight be bad cable and try the latest updates for the player from creative ok
Jan 26, 2008 | HP Creative Sound Blaster Audigy 5.1
Hoover AAA140 Front Load Washer Logo
27 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
