Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Dishwasher fills with water when running faucet
I have a double sink and when running water into the right sink, closest to the dishwasher, the floor of the dishwasher backs up with water and it has flooded several times. my brother tells me there is a s-trap under the kitchen sink. could this be the problem?
    President:
  • 1,214 Answers
The drain hose from the dishwasher should exit the dishwasher, then head up to the nderside of the counter top, before heading back down to connect to the disposal drain connection.
If the drain hose doesn't do this, the dishwasher is improperly installed, and clean dishes risk being contaminated, which can cause people to become ill.
Posted on Jan 25, 2009
The drain hose vibrates while dishwasher is running unless sink faucet is on, which stops the vibration.
Try throttling back (reducing the water flow) the valve that feeds the machine. With the sink tap/faucet running the pressure into the dishwasher is reduced. Is the feed pipe kinked or blocked in some way as there might be a sensor in the machine that doesn't like it when water is "jetted" in under pressure. It would act like putting your thumb over the end of a hose when washing a car.
Jul 21, 2015 | Dishwashers
Low water pressure at sink following reinstallation
if low pressure is only on the dishwasher and not sink.check both hoses going to dishwasher for clogs,rubber washer out of line or debris .if low pressure is only at sink ..you could also remove faucet filter ring at tip for sediment or debris .or lastly check valve under sink cabinet that feeds both sink and dishwasher
Dec 15, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
THe dishwasher is not draining and runs out onto the floor. What should we do?
Drain is plugged between the sink and dishwasher. It has to be unclogged. best advice call a plumber. other tricks fill up the sink with water and use a plunger to pull the sludge through.
Feb 25, 2014 | Fagor 24 in. FI-48W Dishwasher
Why would have a water leak from the bottom of the dishwasher or the right side down by the floor between the dishwasher and the wall to the left side of sink? Leak happenns when running the faucet or...
You could have a leek in the trap under the bench, (the drain plug)
Check the trap is tight,
Check the drain pipe is connected to the sink correctly
Maybe the water is leaking through the bench (there might be a gap / hole in, or on, the side of the bench) some sika sealant could fix this.
Hope this helps, don,t forget to rate or add a comment
Feb 10, 2014 | Kenmore Dishwashers
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
Haier HLP21N washer won't fill. Water runs right through from the faucet to the drain hose.
Is the hose in the sink or on the floor? If in the sink, it sounds like the pump is running all the time. If the hose is too low, it maybe syphoning out the water as fast as its going in.
Nov 08, 2013 | Haier Washing Machines
Can't disconnect the dishwasher from the water supply -- the faucet starts running the moment I disconnect it. I've closed the faucet all the way (as best I can, with a plier), and it still runs.
you can turn the water off using the main water valve that is located under the sink -- this will close all water off to the dishwasher and to the faucet.
c...
Dec 31, 2010 | Dishwashers
Fills arbitrarily not holding any water after a full cycle. All seems well and on any given day it will have filled without warning and floods floor
Check your drain hose to where it connects under the sink. If it is connected to the garbage disposer, and not looped upwards before it runs back to the dishwasher, it may just be drain water from the sink running back to the dishwasher. Even if it hooks up to a "t" spout under the sink, and the drains run a little slow, water can still run back to the dishwasher. The ideal set up is to have it connect to the drainage, run up behind the bowls of the sink, and then back to the dishwasher.
If this is not the answer, then you may have a defective fill valve that is allowing water to seep into the machine (very unusual in dishwashers). Also note that water valves require 23 psi of pressure to seat closed and if the incoming pressure is less than that, even a new valve may have the same issue.
Good luck and let me know how you make out, and if you have any other questions.
Bob
Jun 28, 2010 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
My dishwasher is not heating the water up just running cold
Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
Jan 15, 2010 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
149 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
