Question about Astraware Limited Astraware Sudoku
Crosswords won't load anymore on my nook
Tried to play crosswords on my nook and a screen comes up saying to choose continue or restore defaults and neither one works
I am having the same issue with my cross word puzzles...a screen comes up saying to choose continue or restore and neither are working, the puzzles flashes on and then disappears...I too would like to know how to play the puzzles I have paid for.
Posted on Mar 29, 2016
Howto remove unknown picture on unlock button on hdplus
It's part of your profile. Press the top left corner of your screen where it says YourName's NOOK. Select your profile and select edit profile and select edit profile. Your profile will change to edit YourName. Select this and select change image. This will call up the Galley app to choose from the images. The default startup images are kept in the avatars folder. The default startup image is the green apple.
Jul 09, 2014 | Nook HD+
Tip
8 Steps to Fixing Any PS3 Issue
Note: If your PS3 is on, but you are looking at a blank screen, you PS3 may be in HD mode.
  • Turn off your PS3.
  • Hold down the power button for 2 beeps. This will reset your PS3 video to standard output.
  • If you are unable to reset your video, skip to Step 8.
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
on Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Nook won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 14, 2012 | Barnes & Noble Nook Simple Touch eBook...
Why won't my compaq presario 1250 load windows?
1 - You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose safe mode).
Win 7 - Start > Search type System Restore
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
2 - Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 11, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I have a HP 7600 with xp, I restored using xp disc to fix 1 problem then when it reboots it continually goes into safe mode then I get, restore cant restore in safe mode press ok to restart. Can some
Let the machine boot up into safe mode. You'll get a screen that will ask you if you want to go into system restore. Choose YES and it will come up with a calendar of different restore points. Choose a date point where you know the computer was working and then let it restore.
If this doesn't fix the issue then windows is corrupted and you'll need backup your data and reinstall windows completely.
Feb 05, 2012 | HP Computers & Internet
My lenove laptop shut down and will not reboot
Turn on your system, then start tapping the F8 function key several times during the boot period.You should get a short text menu.
If you can get that far, choose 'Safe mode' which will load only the minimum of drivers and this will often allow you to examine the system for problems.
Your Desktop won't look as accustomed since it will be shown at the lowest video resolution and this will make the icons must larger and more crude but this is normal.
You didn't mention which version of MS Windows you have installed so continuing from that point is not the same for each but you should have a late enough version to have Restore available.
- Click on 'Start.'- Then choose 'All programs.'- Look for and click on 'System Recovery.' - On that short menu, click on 'System Recovery.'
Continue from there and if the Restore tracking has been active (it is by default), you should have several earlier dates to choose from.Select one of these to try to achieve a file condition that will allow you to reboot to a healthy system again.
Oct 21, 2011 | Lenovo G550-29583AU Notebook
When I turn my emachines netbook on, it gives me a error screen saying 'run in safe mode (recommended) and 'start windows normally'. No matter which I choose, it goes to the windows load screen...
there is a recovery tool on emachines usually loaded during you boot the system to safe mode. on my case i restore my machine to its default and reinstall my o/s.. hope it helps
Sep 05, 2011 | eMachines eM250-1915 Netbook
My ps3 does not load games or movies, screen stays still with the circular load symbol at the the top right corner, anything i can do at home to fix this?
Try this:
Mar 25, 2010 | Video Game Consoles & Games
I need to reset my aspire 4315 series back to factory settings as it's not running properly, I've lost my hand book and can't remember what to do, could you possibly tell me what buttons to press when to...
First plug in the Notebook to a power socket with your adapter. Power on the Notebook and you will see the Acer splash screen. Immediately prell ALT and keep tapping F10 at the same time. It will take you to a screen where you will see "windows is loading files" or "starting acer recovery" it will ask you, how do you want to restore?" choose the option "restore to factory default" and click continue. It will go through the restore process and within 15 - 20 minutes it should finish the process. Your Notebook will be back to factory default settings and once again you can see the OOBE.
Hope you find this solution helpful.
We appreciate your comments and feedbacks, Please do not forget to leave your comments and ratings.
Thank you for choosing Fixya.
Nov 15, 2009 | Acer Aspire 4315 Notebook
Astraware Limited Astraware Sudoku Logo
661 people viewed this question
Top Astraware Limited Apps Experts
Are you an Astraware Limited App Expert? Answer questions, earn points and help others
