Question about Brother HL 2140 Laser Printer
Paper Jam I have a paper jam and I can't get it released. What do I do?
  • 95 Answers
Do you see where the paper is stuck. Try to pull the paper out. Look for release door on the back of the printer. Or you can refer to the user manual on this link for easy assistance.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Posted on Jan 25, 2009
  • 29 Answers
SOURCE: paper jam
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 05, 2008
  • 13433 Answers
SOURCE: Paper Jam lite is on ( no paper jam )
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
  • 72 Answers
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Posted on Jul 22, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
pineworks
  • 4041 Answers
SOURCE: No paper jam but still says there is a paper jam
Hello there even if you not see any thing jams it worth a try. There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 15, 2010
ESP Office 2150 all-in-one
Shows paper jam. no paper in machine
Apr 11, 2016 | Kodak Office Equipment & Supplies
I face a paper jam a lot, what is the right steps to release it? I keep getting a paper jam message. I have opened up the case and inspected; removed the cartridge and inspected; no paper/paper jam found....
Turn printer upside down (yes), and check that there is no small paper or foreign objects inside the printer, ensure all door are closed, unplug printer power cable for 2 minutes to reset.
Jul 29, 2008 | Konica Minolta PagePro 1350W Laser Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Paper jam in pixmamp140
To fix a paper jam, you must first locate where in the printer the paper jam is, if your printer has multiple paper trays.
  • When you have located the jam, turn the printer off.
  • If you can see the paper, remove it slowly and carefully with both hands by pulling the edge out in the direction it would naturally be released.
  • Open the printer door to look for any stuck paper.
  • If there are bits of paper still inside the printer, take a piece of heavy-weight paper or cover stock and push it through the printer in the same path. This will push out any bits of paper.
  • Turn the printer back on. Repeat the steps if the printer still alerts you to a paper jam.
Jan 10, 2010 | Office Equipment & Supplies
Paper jam message...but no paper is jamming system
is a small finger plastic, stucked on the paper path, release-it and problem solved. (Is very fragile, so use a small tool to release)
Dec 29, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Roller drags several sheets of paper and results in a paper jam
Open your printer and release jam paper then solve problem.
Apr 09, 2009 | Lexmark E322 Laser Printer
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Brother HL 2140 Laser Printer Logo
423 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
