Hole in door gasket of a Hotpoint 9901w washer dryer.
I have a hole in door gasket of a Hotpoint 9901w washer dryer. Is this easy to replace?
  • Washing Mach... Master
  • 3,463 Answers
It is quite involved to change the seal, as requires a partial strip down, if the hole is not very big, then you can do a fairly good repair using a bicycle punture repair kit..
Remove the plastic clip that holds the clamp ring on the front of the washer seal at the top, remove the clamp ring, take note how it is fitted, then pull seal off front of washer, and fit patch on underside of seal, refit seal and clamp,and job done!!!!
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
How to flip a door on hotpoint fzfm171
handle and hinges all removed to opes it side little plugs are in door and ref for this middle hing may bet turned upside down or pin removed to different hole if not handy call a service co. this is not easy all the time make sure all spacer washers are in same place when re installing take pictures as you take apart
Nov 06, 2014 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Replacing door gasket
Most door gaskets are available online, most recommended taking drum out to replace, but task can easily be done by removing rubber from hole in machine (end of a spoon helps) then push drum back through the hole and you will see a large clip on rubber to the drum, unscrew clip and pull out rubber, reverse to replace. Good luck.
Feb 19, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Leaking gasket
Need to replace your boot seal. If you do not what to go to that expense, if the hole is small you can use silicon sealer to patch the hole and let it set for at least 24 hours.
Jan 25, 2013 | Maytag MAH6700AWW Neptune Front-Load...
Hotpoint dryer dlb155obdlad will not turn. just replaced the belt.
first check to see if you can manually turn the drum ..then go to back of dryer in the center their is a cover plate...remove 2 screws to see the drum shaft ...remove the snap ring to remove the 2metal washers..and 1 fiber washer ..their should be a fiber sleave/bearing that slides onto the shaft that is in a metal bracket ...this is the rear support for the drum ..its prob.. out of bracket an grinding a big er hole ///or the front of the dryer drum slides are bad ..if you did the belt they are on top of the front panel of the dryer door they are plastic slides ..the inside of the drum has to be ontop of them to rotate ....let me know an good luck.../joe/
Aug 30, 2010 | Hotpoint NLL113EYWO Electric Dryer
Whole in seal and a smell
Is the hole, or a tear? If its a hole, that's the normal hole to get the excess water out of the door gasket. If there is a tear, you'll need to replace the door gasket. The smell you get, is due to not leaving the door open, you'll need to leave this, and the dispencer open all the time, when your not washing. The unit needs to vent, in order not to have build-up of mildew/mold.
Mar 28, 2010 | Hotpoint Washing Machines
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
There is water leaking from the bottom of my machine. its not the drain pipe but can't find my manual to see where the filter is. could that be the problem many thanks Sue
Unlikely to be filter leaking.
Carefully check the door seal for a split or hole in it, it is easy to miss a hole, so examine it closely.
The filter is located inside the large black hose fastened to bottom of drum.
Hope this helps.
Jan 31, 2010 | Hotpoint Aquarius WD63 Front Load...
Red flashing key hole sign
Hi.
If red keyhole symblo is flashing continuously, make sure the door is firmly closed. this should then clear the symbol.
Hope this solves your problem. Come back to me if you need more info.
Please leave feedback.
Thanks
Nov 26, 2008 | Hotpoint WMA74 Front Load Washer
Hotpoint Washer Dryer Leak in left corner
watch the drawer closely as it fills, on out side of machine it might be hard to see or else small hole in door seal also hard to find good luck luck close ire
Nov 27, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint ultima washer dryer
isolate from mains. undo door gasket and check interlock id ok. interlock is mounted on cabinet on rhs
Mar 11, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
