I have a cloud9 airconditioner without operating manual. can anybody help me with one
Split airconditioner. indoor unit.model kfr-32gw/h
bobotfel
  • 236 Answers
SOURCE: MANUAL OPERATION OF SPLIT SYSTEM AIRCONDITIONER
In every model there different location of manual button. Some manual button are located in front of the indoor and some are at the back of the front grille near the control board.
Posted on Jan 24, 2008
SOURCE: NEED SERVICE MANUAL FOR FUJITSU SPLIT SYSTEM
try, http://www.uelements.com/downloads/Fj-aby14rga-sm.pdf
Posted on Jan 07, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
SOURCE: I have a Chigo Mini Split KF-32GW/A. What is
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
1、Check whether two sets of plugs on the outlet end of
the motor have loosed from the socket of the
electric control board, insert it firmly when loosing.
2、Check whether the indoor motor has damaged, the
motor should be replaced when it is damaged
3、 Check whether the controllable silicon and other
components on the electric control board have
damaged, replace the controllable silicon or electric
control board when they are damaged.
Posted on Jun 26, 2010
SOURCE: we have a msz-ga80va split
Just had the same thing happen to us with the same model (right on Xmas day).
Checked the circuit breaker is on in the fuse box. Power is on to the external unit. Filters are clean.
Internal unit activates... both indicator lights on. After 5 minutes blowing air it stops and the right indicator light goes out and the left indicator light blinks constantly.
The troubleshooting guide inside the internal unit (under the outer cover you open to clean the filters) suggests that 14 blinks is an abnormality with the external unit and refer to service manual.
Think we'll be calling a technician.
Posted on Jan 02, 2011
Chunlan kfr-700k
Check this link to see if you can find the manual you are looking for here:
http://shop.panasonic.com/shop/model/36PEF1U6?t=specs
Aug 26, 2014 | Panasonic S-36PF1U6 31,200 BTU Mini-Split...
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
Model: KFR-32GW/Ac Will not stop leaking water from the front of the unit. Coils have no ice. Shut off unit for 30 min the leaking stops but resumes when AC is turned back on.
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Aug 08, 2010 | Heating & Cooling
E5
PG motor
display at
off state
flicker 5/7
SEC
display
at off
state
no feedback
signal of indoor
fan
Jun 12, 2010 | Heating & Cooling
How to clean the filters in split airconditioners
Check on top of the indoor unit. On some models, the filter will slide out from there without having to open the cabinet. On others you will need to pull on the top front and the panel will swing down (it will be hinged) and the filter will be behind that panel.
Mar 24, 2010 | Heating & Cooling
My mini split only sometimes responds to the remote
indoor pcb in the indoor unit faulty and the responder.
Jun 09, 2009 | Soleus KFR-18GW Split System Air...
Delonghi PAC S1000 Split Airconditioner
hello you will need to pump system down and disconnect flare nut or decant gas and then undo flare nutsthis is the only way to remove unit
Jan 10, 2009 | Heating & Cooling
Jan 24, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
