Question about Plumbing
Driping taps the tats i have in my home are not the type that you turn to get the water to run they are what i call the new type. when you want the water to run you turn a leaver which is on top of the tap.is there a washer in them which needs renewing if it drips
  • Ron Krysiewski May 11, 2010
    This type of faucet is called a single lever, and they been around for years. I understand it is dripping but it is very hard to explain how to repair it without seeing the faucet. Common one's are Delta, Moen, American Standard. All have different repair replacements. Some easy and some difficult. If your not sure call a Pro!
    President:
  • 2,692 Answers
Take it apart and take the parts to the plumbing supply and match them up. If you cannot live with the drip would you not replace it anyway if you cannot repair it?
Posted on Jan 30, 2009
Occasional loud humming or vibration type noise when hot or cold water taps are turned off after a short period
indicates water hammer in the pipes or faulty stop washers in the taps allowing the vibration from escaping water under the tap washer
ha a plumber reseat all taps and fit new washers
Aug 31, 2017 | Washing Machines
How to stop a driping tap
Try to follow these two you tube videos and see which one applies to your style of faucet.
Good luck.
How to change or tap washer to stop dripping tap or replace the type of...
How To Fix Dripping Tap Washer Change Plumbing Tips
Aug 05, 2014 | Plumbing
Air lock in hot water tap in kitchen. tap was left running, how do we fix?
connect a hose from the cold tap to the hot and turn on hot tap then turn on cold tap slowly and watch for air bubbles in hot tank header if you have one, but 30 seconds should be enough. turn both taps off then try hot tap for flow, it should have cleared the air lock. You have not stated what type of system you have or if it is a pressurised system. my fix is for the old type copper cylinder and header tank system and not for a pressurised system that are mains pressure fed..
Nov 26, 2013 | JumpUSA Dribble Specs No Look Basketball...
Air in bathroom cold water pipes
You have to install anti knock pipes into your plumbing, it's quite common. Go to the local home center you can by pre made or make your own as I did when remodeling my basins. Good Luck..
Oct 20, 2012 | Home
No hot water from hot taps at all.
IT SOUNDS LIKE YOU HAVE A BURNT OUT HEATING ELEMENT YOU PROBABLY HAVE TWO IN THIS UNIT CH YOUR CERKET BREAKER FIRST IF OK DRAIN THE UNIT TURN BREAKER OFF RE MOVE ELEMENTS THAY ARE BEHIND THE COVERS THAY HAVE PHILIP'S SCREWS TAKE THEM TO LOWS OR HOME DEPOT MATCH WITH NEW ONES PUT THE NEW ONES IN FILL THE UNIT WITH WATER OPEN A WATER TAP LET RUN TILL ALL THE AIR IS OUT THEN TURN THE POWER BACK ON HOPE THIS HELPS GOOD LUCK BOB
Apr 25, 2011 | Reliance & 40 Gal Mobile Home Water Heater...
Installed upgrade to water heater and piolet light lit fine. for a minute the flame turned yellow as condensation driped but when it stopped flame went back to blue.
New gas water heaters drip condensation the first time they are lit.
The dripping stops.
You should be fine.
Keep us posted.
You can add a comment and I will help further if needed.
Nov 03, 2010 | Whirlpool Water Heaters
Hi there i seem to have a problem with my shower it was working fine but now its running like a driping tap ther is to presher and its not the head because its the same with the head off
If it has a single valve in the center you have gotton dirt in the valve and this is stopping the water from flowing, it is notto diffiuclt to fix if you know how to turn the water off let me know and I will tell you how to take it apart and clean it.
Oct 06, 2009 | Water Pik Hand Held Shower
Slow water dispener
there s a motor present for the working of the water dispenser whose rpm would be slow due to which the water dispenser is slow so change tat motor or repair it and then use it after tat it will work properly
Jul 22, 2008 | KitchenAid Superba Architect KSCS25INSS...
Leak at Bottom of Door
ya that sealing would have gone bad try to attach a rubber fitting with it tat will stop flow of soap suds
Jul 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
Plumbing Logo
91 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
