Sc402 ricoh mp5500 - Office Equipment & Supplies
3 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Fault code SC402
Transfer roller leak error 2
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
transfer roller is not detected.
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Posted on Jan 02, 2008
hamzaskilltd
  • 316 Answers
SOURCE: Error Code SC402 in Ricoh Aficio 270
transfer roller negative current error
Posted on Jun 26, 2010
My mp5500 prints real faint but it has new toner cartidge
Try cleaning the laser unit. If unsure how, give your nearest Ricoh distributor a call to log a service call.
Jun 12, 2014 | Ricoh Aficio Office Equipment & Supplies
Error code on display. Sc402. what does the error
Transfer problem
Your Transfer unit disconnected or bad connection.
Unlikely, but a transfer power supply could be faulty.
A piece of paper stuck in the transfer area could also cause that code to come up.
If the machine is dirty and you see toner all over when you open the right side of the copier, have it cleaned thoroughly, that will most likely solve your problem.
Aug 24, 2011 | Ricoh Aficio 120 Copier
Ricoh mp5500 printing light copies
how many copies has the drum & developer yielded.If it more than 60K then replace it
Aug 15, 2011 | Ricoh Office Equipment & Supplies
Hello!
Is it only in copies? If so you need to clean the all scanner (glasses ans mirrors)
If that happens also when you print it could be one of this problems;
-The laser (durt)
-The Magnetic Roller (in the development unit)
-Or the Developer.
The question is: When was the last time that you did a service maintenence??? Maybe you need to do that.
See you!
I would like to know how to recover store copies from a Ricoh MP5500 copier. Is it possible?
The copies that you take are not saved in the HDD (hard drive). So, the answer is NO.
You can only recover the documents that are stored in the Document Server.
See you!
May 05, 2011 | Ricoh Office Equipment & Supplies
Fuctional problems sc402. ricoh aficio 150
SC402: Transfer roller leak error 2
A transfer roller current leak signal is detected.
The current feedback signal for the transfer roller is not detected.
- Possible causes -
  • · High voltage supply board defective
  • · Poor connection of the PCU
  • · Transfer/separation unit set incorrectly
  • · Transfer roller damaged
Jan 26, 2011 | Ricoh Aficio 150 Copier
Jun 25, 2010 | Ricoh Aficio 180 Laser Printer
I have a ricoh 1022 giving me an erro message "Funtional problem within copier" code sc402. can you send me step by step to fix this problem?
Transfer roller leak error negative electrode.The feedback voltage of the transfer roller is insufficient.Verify the correct instalation of the transfer unit or the separation unit.Check and clean the transfer roller.Verify the connection of the PCU unit(loose).
Nov 21, 2009 | Ricoh Office Equipment & Supplies
Fault code SC402
roller is detected.
incorrectly
Thanks J
Nov 19, 2007 | Ricoh Aficio 180 Laser Printer
101 people viewed this question
jasbo
jasbo
