Question about Hoover F7210-900 SteamVac V2 Upright Wet/Dry Vacuum
Brushes won't spin
I have the hoover steamvac F7410-900. My problem is the brushes won't spin, even though the motor is running, and the "brushes on-off" switch doesn't do anything.
  • 1 more comment
  • dogbreath 2 Jan 26, 2008
    I have removed the brush unit and the plastic post that is in the center of the unit has broken off.  This is the second time this has happened.
  • bus23 Feb 04, 2008
    I have same problem with brushes. The belt and motor are fine. The brush that drives the assembly has a long plastic peg. The peg broke off inside the plastic housing. Where can I get a replacement brush assembly? I also need to figure out how to get the piece that broke off out of the plastic housing. Can anyone tell me where to get the replacement and how much it will be? thanks
  • Mike Little May 11, 2010
    Does anyone know what the stem on the brushes actually looks like? I took mine apart and can't really tell if the stem is broke or not. It appears to be twisted somewhat at the top but I can't tell if it is actually broke or the part is just made this way.
Funny, lots of Hoover steamvacs seem to have this exact problem. I just fixed mine today and it was a problem with the turbine that spins the brushes. It took me a while to get to the part without breaking the plastic housing. If you have the patience, you should have no problem figuring it out. When I got to the turbine part, I opened it up and found that the metal disc at the end of the shaft was rusted and that no grease was ever applied. I took a metal brush, cleaned it up, greased the wheel, and then closed it back up. After putting it back together, it worked great. It almost looks like they don't grease this part on purpose so that it rusts and fails in order for you to spend more (buy parts, extended warranty, etc.). There's tons of grease on one of the other wheels that doesn't even need it. The product works great other than this. I've had mine for about 1 and 1/2 years and this is the first problem I've had with it.
Posted on Jul 30, 2007
  • 641 Answers
Open unit's bottem cover and look for the following: - Motor works - Belt which transfer motor's movment to the brushes, in place and not broken (most frequent phenomenon). - No mess on brushes axis which prevent their free movement. Good luck
Posted on Jul 16, 2007
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brush does not spin on my steamvac v.
the engine or electric motor must have been shorted by water getting past seal
Oct 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac SpinScrub. The brushes
If the speed control switch on the hood is in the On position, it would appear the drive mechanism for the brushes is not spinning internally. The drive mechanism could easily be replaced by a technician.
Oct 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Spin brushes wont spin and the switch wont turn machine off. I have to unplug it.
for the spin brushes it is most likely the motor is fried if you smell something burning it could be jammed or the wires have be shaken off the motor terminals. for it not turning off you need a new switch.
Jul 29, 2009 | Hoover F7431-900 SteamVac Vacuum
Brushes won"t spin, Model F7452-900
SAME PROBLEM Hoover F7452 900 brushes won't spin; cleaned and move freely, under filter slid out and cleaned, still froze up....had it a little more than a year so probably no warranty.....assuming turbine related and will take it to dealer......how common is this problem with this model???
Jun 15, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover F7210-900 SteamVac V2 Upright Wet/Dry Vacuum Logo
486 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
