Question about Acer Aspire 5100 Notebook
Screen picture froze, powerd down, powerd up, blank screen
Charged by connecting charger to acer laptop, powered up, hearing fan, seeing power lit on, still no picture on screen, do you think the backlight burned out??? or something else??? computer is about 4 months old, i don't know why screen went blank all of a sudden...
please advise....thank you....
  • Anonymous Feb 05, 2009
    my advent laptop kept frezzing so i kewpt having to switch it of on the power button ( cdnt swtich if of via shut down option in start menu)]
    now when i turn it on its goes black i can move the mouse but thats it i can get into safe mood e.tc nothings worked
    what do i do
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Hiya
Try pressing Fn F5 or Fn F6, these usually turn the screen off and on. They usually have little blue rectangles on them, representing the screen. If another F key has the rectangles, try that one while holding the Fn Key. As it froze on you first, it could be more sinister, ie a hardware fault, You could try removing the power and battery for 20 seconds, then try powering on again once you replace them. If all this fails, i'm afraid it ack to the shop for a repair.
I hope this helps.
Lesley x
Posted on Jan 25, 2009
Open cbinet of crt,
then internally check circuit connection.
or check for external lead connect very well or not ,one of power,and data cable.
I have an Acer G246HL. When I turn it on the power saver symbol comes on, then the screen goes blank. (ie no picture)
I would suspect the battery is failing in this, even with the AC wall plug adapter connected the unit's battery must be good to function correctly, the AC wall charger is designed to charge the battery not power the entire PC laptop.
Nov 04, 2016 | Acer Computers & Internet
My zg5 laptop battery will not power my laptop.battery is new. fully charged.
Hi John,
For the sake of clarity: the battery which will not charge/power your Acer Aspire One Netbook is the original battery that came with the Acer, is this correct?
Assuming that the answer is Yes then replacement with a NON Acer, universal battery is the only solution.
Reputable internet shops, such as Amazon, have these at around $50...
DANGER; Due to the recall of thousands of Acer (HP and others) batteries with a possible fire hazard please dispose of promptly and properly.
Best Buy has a Recycle program:
http://www.bestbuy.com/site/Global-Promotions/Recycle-FAQs/pcmcat174700050009.c?id=pcmcat174700050009
If this link does not work please Google Best Buy Recycle
Thanks!
Jimm
Nov 20, 2012 | Acer Aspire One Netbook 8.9" Notebook
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
Dear support specialist, My acer laptop is not sho...
I had a problem similar to this with an ACER 7720G laptop going through the motions of starting up but no screen although I could see some fient images and found it to be the wrong charger for the laptop.
Try this: -
If you are connected to the charger disconnect it from the laptop. If the laptop screen comes up you have a problem with the charger. Try another charger and see if the problem exists.
Chappo07
May 20, 2010 | Acer Aspire 7110-2069 Notebook
Acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
Aug 02, 2009 | Acer Aspire 7720 Notebook
I have an acer laptop. When you turn it on you can hear it running but the screen stays blank
Is the screen black(unlit) or blank? If it's not lit, use a bright torch to see if there is a picture, and it means the backlight has gone, which is an easy fix.
Jul 08, 2009 | Acer Computers & Internet
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
Acer Aspire 5100 Notebook Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
