My samsung DVD-D360k doesnt read my usb and displays "MODE NOT SUPPORTED"
Stuck in demo mode / demo lock
Put the unit in dvd mode. then press and hold the stop and eject buttons. The display should read "demo off". Then the tray should operate normally.
May 28, 2013 | Sony BDV-E280 Home Theater System - 3.1 3D...
Samsung dvd-d530 doesnt play usb. Please tell me how to reset factory settings or original grid code.
i I have a problem with my samsung dvd D530, it doesn't read the disc or the usb anymore. i cannot even enter the settings,all I get on the tv screen is ''no option''. can anyone tell me how to reset it?until yesterday it worked perfectly fine.
Jul 30, 2011 | Televison & Video
Hi, I have a Samsung DVD Player H1080 R. Nice player with sleek design. When I try to connect my Seagate Go Flex USB 2.0 Plug & Play (1 TB), it doesnt play. There is data in the external hard disk,...
Good day!
These are the 2 possible causes and solution on that problem:
  • The format of the file on U.S.B device is not compatible to the format requirements of the DVD player.For example your DVD player required A.V.I or MPG/M-PEG for the video while the file format of your U.S.B is F.L.V and when you try to insert it to the U.S.B port the file doesn't read.You have to do is convert the file that store on your U.S.B device depends on the format requirement of your DVD.Use a total video converter to convert the file on your U.S.B to the format you need to play on the DVD player.
  • Or the problem could be the U.S.B itself,because the U.S.B host on this product does not supported all U.S.B device.Please try to use other mass media device such as memory card or mp3 players.
I hope this solution will be helpful.Thank you.
May 02, 2011 | Samsung DVD-H1080R DVD Player
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Jan 20, 2011 | Samsung BD-P1590 Blu-Ray Player
I have a samsung external dvdw drive SE-S084C/RSBN and it has stopped reading dvd's. It still writes dvd but will not read them even after it burns them. I was told downloading the newest firmware would...
Samsung External Slim DVD-W USB Compatible with Mac and PC (SE-S084C/RSBN Burner) automatically upgrades the latest firmware version through internet.
Here is the samsung Official Product Support link. Firmware is available only only for Windows. Therefore i recommend that you connect you external drive with any other system with windows operating system and upgrade the firmware. Moreover, User's Manual and other related information and details are also available.
Also, try using CD/DVD ROM Cleaner because there may be some dust inside the drive that may prevent it from reading the disks.
Good Luck!
Hope this helps!
CreativeTECH
Dec 13, 2010 | Samsung External Slim DVD-W USB Compatible...
Panasonic sa-pt850 dvd not displaying on samsung tv
I am having the same issue, so if you have found a solution, please let me know!!
Feb 09, 2010 | Panasonic Televison & Video
My dvd player doesnt read or play dvds
Here you go:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=sd616&dType=D&mType=&model_cd=&menu=download&prd_ia_cd=&disp_nm=sd616&isEqualsY=
Take care.
Jul 02, 2009 | Computers & Internet
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
Dvd troubleshoot
try to clean the lens using coton and water if not working change the lens.
Sep 16, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
