Question about Bosch 23 in. SHU33A Built-In Dishwasher
Upper Rack We got Bosch after our old dishwasher broke. But the Bosch has a MUCH worse upper rack. We can't figure out how to stack glasses so they don't fall over. Are we missing parts or did we buy the El Cheapo? Is there a better rack? Mac
  • Anonymous Nov 04, 2007
    We built a new home and got a bosch dishwasher.. You are supposed to be able to snap the bottom prongs to lay things flat but they come apart from the sides and I spend alot of time snapping them back in when I have dishes. I absolutely hate this bottom rack and get frustrated everytime I use my dishwaher. It is a very poor design. any salutions ? Barbara
  • 51 Answers
Contact Bosch and ask if there are any other rack configurations for this model. From memory I think there might be 1. I also remember that they made an insert to go into this particular top draw...check on that also Regards
Posted on Jul 24, 2007
SOURCE:
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
How do i remove my old upper rack ?
u should be able to pull out and lift up to remove racks
May 22, 2010 | Maytag 24 in. MDB4000 Built-in Dishwasher
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Upper wash tube assembly came off back of unit. can not reattach.
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Nov 30, 2008 | Dishwashers
Top rack is not level. Glasses and cups roll forward
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
Oct 12, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Kenmore 665.16389300
Test by pulling out the lower rack and run an upper load, it may just be a loading issue. Some washers are better than others, in that they have stronger moters and impelors than others. The impellor may have something like a fork, knife, or broken glass in it.
Jun 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwaser not rinsing properly
I had this problem twice with my Bosch and both times required different fixes but they both worked. 1. I got this one out of the manual. Make SURE that you push the upper rack totally back. There is a connection back there that fits into a fitting on the back of the rack and pushes the water through the upper arm. 2. I had taken off the extra rack that attaches to the back of the lower rack. Then I put it back on wrong. It should not have the prongs appearing behind the rack. Both of these situations caused cloudy/dirty dishes. Also, because of the lack of water, it clogged up the filters. Remove the filters and clean them well. Then make sure you have neither of these issues going on. My dishwasher returned to great washing.
May 01, 2008 | Dishwashers
Upper rack travel sticks and jams.....
you have a bad bearing retainer. you will need to call an asko parts dealer and order 8 upper rack ball bearings, and two ball bearing guides (they are grey plastic and break over time, causing the rack to jam. To replace tham, you must take the upper rack out by turning the plastic retainers on the front of both rails 90 degrees towards the outside of the machine. The slide the whole basket out. Now look at the back of the rails inside the dishwasher. there shoul be 2 more grey plastic retainers with bumpers on them in the rear. These must be pried out wiht a screwdriver (be careful, have cut myself several times on this job till i figured out the best way to do it. cover the bottom hole in the dishwasher with a rag, as you are likely to drop the old bearings when you slide the rails out. Slide out both the rails. Put your new (or old if youve got all 8) ball bearings into the ball bearing holders, then put the holders into the rail thats attached to the dishwasher. slide the rails back in, andthen put all your retainers back in and your rack. you may have to slide the rack in and out a few times before it will center the bearings and work smoothly. Should cost you about $12 in parts. Good Luck!
Apr 17, 2007 | Asko D1716 Built-in Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Bosch 23 in. SHU33A Built-In Dishwasher Logo
159 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
