Question about Apple Computers & Internet
External samsung monitor is not displaying same resolution like macbook pro
Hi, i am having some issues in getting the exact resolution like my macbook pro on an extended samsung S24B150 display ...
davecon
  • 85 Answers
SOURCE: X2gen MV19 monitor: can only get VGA resolution
unscrew the monitor check behind the line transformer you will see two buttons for adjustment use them to increase your resolution manually
pls make sure the monitor is shut down for abt 15-30 minutes before you attempt opening it to avoid electric shock
Posted on Apr 22, 2008
skotkolr
  • 558 Answers
SOURCE: Monitor will not display in native resolution.
sounds to me like they replaced your vga board with another compatible one but not the same exact one I would call the repair facility that did the work and ask questions about how they repaired the monitor like if they used another vga board etc. hope this helps
Posted on Jun 19, 2008
antiochpc
  • 1314 Answers
SOURCE: MONITOR RESOLUTION PROBLEMS
This is a limitation of your video card. First, make sure you have the most up to date graphics driver available for the video card that you have. If that doesn't help, then you will need to add or replace the video card.
Thanks and please take a moment to rate as fixya.
Posted on Dec 11, 2008
Mole72
  • 30 Answers
SOURCE: Acer x223W Monitor issue - not displaying correctly in native resolution
hi, when all connected press and hold the FN key on the bottom left of the keypad while pressing one of the function keys F1 to F12(the one with picture of a screen or monitor). You may need to press it more than once but if will eventually switch the display over to the tv
Hope this help
Posted on Dec 13, 2008
  • 1684 Answers
SOURCE: Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Oct 24, 2009
When I plug in my MacBook Pro (Mid 2012) via Mini-display to HDMI or even VGA the color of the Samsung TV changes color (Super Saturated). Oddly enough when I BootCamp into Windows 7 via same connection,...
There are issues with OSX on some monitors. On Lion and older OSX, you may get better results by playing with your Macbook screen settings and resolution. OR I found many of these issues were addressed when I upgraded to OSX Mavericks (free) it now handles external displays and resolutions much better. But you might simply have inadvertanly set the wrong color profile. Go to Finder: then System preferences then Displays. Choose the Color tab/button and select one of the color profiles or choose calibrate and follow the prompts
Nov 05, 2013 | Samsung LN-T1954H 19 in. LCD HDTV
HELP! bought a BX2450 Samsung monitor and it`s not showing full resolution, i need a driver for my macbook pro 13` (mid 2010) anyone????
I have a very strong suspicion that you are connecting your Macbook Pro to the VGA input on the monitor instead of the HDMI.
Your Macbook Pro uses the Mini Displayport connection type. Are you using a Mini Displayport to HDMI adapter? If not, purchase one and that will resolve your issue.
If you are already using a Mini Displayport to HDMI adapter, make sure your resolution is set to the maximum (1920x1080 according to Samsung's website) in Apple Menu > System Preferences > Displays > Display.
If available, select the 'Best for Display' option which should automatically set the maximum resolution for the display. If not, select 'Scaled' and choose 1920x1080.
Sep 04, 2013 | Samsung BX2450 LCD Monitor
Monitor rotation from MacBook Pro
Go to system preferences > displays, then there's an option to rotate the display. You'll also need the corresponding cable to connect it. Enjoy the mac!
Dec 11, 2012 | Samsung SyncMaster 2493HM Monitor
I have the HannStar Model #HC194 hooked up to my MacBook Pro. I know the Mac is recognizing the monitor, because when it's hooked up, the hard drive icon disappears and reappears on the Mac when the...
The clicking noise is a hard drive noise and not associated to the monitor. Likely going bad. Maybe an external? The monitor issue being black may be related to the resolution or the "Mhtz" that the display is set at (forgive the grammar). First go into "System Preferences" and change the resolution to a lower resolution. If that works then you can see about further adjustments from there modifying as you need till you get the best results.
Jan 05, 2018 | Hannstar I-Inc iF191DPB 19" LCD Monitor
I'm trying to hook up my Westinghouse L2410NM 24 inch monitor to my MacBook Pro. I'm using the DVI adaptor for my mac to connect to the monitor via an DVI-HDMI cable. My mac seems to detect the L2410NM,...
You need to change the refresh rate, some monitors operate on 60 Hertz, and others on 70 or 72 Hertz, try changing the refresh next to the resolution choices.
Nov 13, 2010 | Apple MacBook Pro Notebook
I have macbook pro and a 30" apple hd cinema display the best resolution I can get on the display is 1280x800 where are the higher resolutions?
Your computer will always give you all available options for resolution. If there is no higher resolution available in the settings screen, there is no higer resolution available for you. This is linked to your graphical processing unit inside your PC. This cannot be changed that easily
Oct 27, 2010 | Apple Cinema HD 30" LCD Monitor
Hi i have an apple display connected to my macbook
Unplug the display from your macbook, and restart your macbook, when it's fully restarted and you are logged in, plug the display back in, then check to see if it is detected. Macbooks don't like to be put to sleep (shutting the lid) with a display connected, this causes issues with display detection. So always unplug your display and wait about 5 seconds before closing the lid on your macbook, and when you open the lid, wait another 5 seconds before plugging in your display. The only time it is acceptable to leave the display plugged in when you close the lid is when you plan to use the macbook in clamshell mode, this is done by plugging in and configuring your display, shutting the lid, and then "waking" the macbook from sleep mode with an external mouse (wired or wireless will work). That will start the macbook using the external display as the main display, without even turning on the macbook built-in display. Never connect or disconnect an external display when your macbook is off or in sleep mode. Have a nice day.
Jun 26, 2010 | Apple Cinema Display Flat Panel Monitor...
I have just hooked up an external monitor (LG Flatron) to my macbook--no problem with web pages, but I am unable to see my desktop or any word files. When I boot up, it says analog in the upper right...
  1. When you connect an external monitor to your MacBook (or PowerBook, for that matter), you can combine your MacBook's LCD and your external monitor to create one big monitor. That means when your mouse pointer goes off the edge of one, it will appear on the other. Open the Displays Preference Pane to configure the resolution and orientation of the two monitors. This type of configuration works well when you want to keep your main work on your larger external display, but still keep things like IM, iTunes, and email constantly visible on the smaller laptop LCD.
  2. Some windows act like they don't want to be dragged on to your external monitor. If a windows is being stubborn, try dragging it up to the menu bar, and keep dragging, even if stays stuck below the menu bar. Sometimes once you have dragged it far enough that it has room to render the entire window, it will jump to the other monitor (Terminal used to have this problem, but Apple fixed it some time ago). If that doesn't work, try dragging it from a corner of your monitor. My Adium contact list doesn't seem to want to live on my external monitor, but I can coerce it up there by dragging up from either corner.
  3. When your laptop is open, you can't switch to using the full resolution of an external monitor. I have no idea why, but it's a fact of life for MacBook users. You can use both displays in "extended" mode, or you can mirror your MacBook's display (which most likely doesn't use the full resolution of your external monitor), but you can't switch to using only the external monitor. Very strange.
  4. If you close your laptop, you can actually get the full resolution of your external display. Put your MacBook to sleep, connect your external display and an external monitor, and wake the computer up by pressing any key. You will have full use of your external display while your laptop is closed.
  5. If you really want to have your MacBook open while only using an external display, after following the procedure above, you can open your MacBook, and it's screen will remain off, which means you can still use the MacBook's keyboard and trackpad. Why you can't get into this mode using F7, I have no idea. This is a good technique for allowing some heat to dissipate while still using an external display so the lid of your MacBook doesn't melt or warp.
  6. You can boot your computer using just an external display. Just connect your external display, open the lid, hit the power button, and close the lid again immediately.
  7. In order to output only to an external monitor, you have to have the power cable connected. I tried for several minutes yesterday to get my MacBook to wake up with an external keyboard and monitor before unpacking my AC adapter from my backpack, and it wouldn't work. It took me a while to make the connection (no pun intended), but I eventually discovered that with the power cable attached, everything works as expected.
Aug 05, 2009 | Apple Refurbished MacBook 2.4GHz Intel...
Screen resolution.
Hello there!
It's fortunately quite easy to adjust the resolution your MacBook Pro sends over to your external display.  Try this:
  1. Click the blue Apple icon, at the top-left of your display (while connected to your 23" external monitor).
  2. Click on "System Preferences".
  3. Click on "Displays" in the "Hardware" row.
  4. A display preferences window should now open on each display... one on your laptop, and one on the 23".
  5. In the "Display" tab of this preference window, specifically the one located on your 23" display, should be a list of resolutions available.  Scroll down and select the highest resolution, which for a 23" should be 1920x1200.
This should adjust your resolution to the maximum.  To make these settings easier to get to in the future, check the box in the display preferences labeled "Show displays in menu bar".  You'll see a small icon, meant to look like a display, appear in your menu bar.  Going forward, you can click on this to set/change resolution settings without going through all the above steps.
Hope this helps!
Oct 10, 2006 | Apple Cinema Display 23" HD Monitor
Computers & Internet Logo
64 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
