Question about Sony STR-DE897 Receiver
Clicking sound from unit occsanially
When I turn it on few a few minutes after it warms up a bit?
    Scholar:
  • 93 Answers
Clicking sound? most receivers resort to this trying to determine what the input source is, and mainly if they are trying to determine if it is a analog or digital input signal, try setting the input source switch to AUTO if available, this way it will recognize the signal and switch to that input mode.
Posted on Jan 25, 2009
Weller Pyropen WPA2 extinguishes itself after a few minutes.
Gas (condensation really) may be freezing and constricting flow. Try warming the tip a bit with a hair dryer see if it goes longer.
Jan 11, 2014 | Weller WPA2 Pyropen Professional Self...
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
Ford probe 24v sport engine, starts ok cold, but after a few minutes warming up it cuts out, leave it for a few minutes and it starts and runs no problems, just the cutting out bit thats a problem
Hi and welcome to FixYa!
Mostly this is caused by a failing coil pack. It is located on the side of the engine where the spark plug wires are attached. You will need to remove the cap to gain access to the coil pack. Once replaced you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
Feb 27, 2011 | Ford Probe Cars & Trucks
2 years old B&D bread machine. Motor doesn't turn. Didn't wait long enough to see if the heater is working.
Hi keneddy,
Always wait a few minutes to see if your bread machine start to mix after a few minutes. If the oven chamber is cold it will gently warm up a few minutes before it starts to knead/mix. This can sometimes take anywhere from 4-5 minutes and longer. If it doesn't start kneading after about 20 minutes then you do have a problem. Whole wheat programs often warm up before any kneading begins. All you will hear is a faint clicking noise while the heat comes on.
Feb 21, 2011 | Black & Decker B2300 Bread Machine
If I have my laptop on for more than a few minutes, the keyboard stops allowing me to type. Why?
Freezes after a few minutes of running normally are quite often heat-related.  You could try cleaning the fans and making sure that air is getting to the warm bits of your computer.  If you're feeling brave, you could unscrew some of the access panels and clean out the dust with a (clean and unused!) paintbrush, making sure that none of the bristles fall out into your computer.
Worth trying, anyway.
Mar 03, 2010 | Gateway 2520915 Keyboard
When I turn my TV on it plays just fine for about 10 minutes. Then it goes to black and white. If I turn it off for a few minutes and then turn it back on, the color returns for a few minutes and them goes...
The tube harnesses may be a little loose and when tube warms they short. Try adjusting the wiring harnesses. (Only attempt to do so if you have electronics knowledge.)
Nov 20, 2009 | Philips Magnavox 27MS343S 27" TV
Amp works for a few minutes
too much power. turn your amp down a bit and let er rip.
Oct 01, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
HEAT ONLY STAYS ON FOR A FEW MINUTES. WE HAVE ALREADY CLEANED OUT ALL THE LINT FROM EVERYWHERE.
replace the 2 coils on the burner . After they warm up , one will "short" , therefore the gas will not come on unless cooled down for a bit .
Aug 14, 2009 | Whirlpool LGB6300 Gas Dryer
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
Sony STR-DE897 Receiver Logo
71 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
