LG F1056QD front loading
Drum sticking with heavy load
  • 210 Answers
SOURCE: LG WM-1280 DD front loading washing machine
When the unit is off, open the door and spin the drum, does the noise occur? If the answer is no then there is nothing wrong with the bearings. Chances are the hall sensor on the motor is on the way out. Call for service and ask them to replace it. Make sure you are using a "HE" branded detergent,,,, less is best.
Sgt 48
Posted on May 31, 2008
  • 113 Answers
SOURCE: LG TROMM WASHING MACHINE FRONT LOAD
Here is text of very helpful email from LG
When you receive the LE error code, unplug the machine for approximately 15 - 20
minutes. This will reset the microprocessor.
The LE error code can be an indication of several different issues.
The most common cause is over-sudsing in the machine. Many times owners
experiencing the LE error code are using regular detergent. It is recommended to
use a high efficiency or low sudsing detergent. Many of the leading detergent
manufacturers have a high-efficiency (HE) selection. The HE detergents are
designed for lower suds levels and enhanced cleaning performance in
front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. A
good rule is to load the washer until the clothes in the drum are no more than
three-fourths of the way up the window of the door. This will allow them
sufficient room for tumbling. The clothing having sufficient room to tumble is
more important than either the weight or the number of items in the washer. It
is the tumbling action that provides the washing effect.
Lastly, a breakdown in the signal between the microprocessor and the motor may
cause the error code. This can occur if there is a loose wire, dislodged ball
sensor, or if the shipping bolts are removed prior to situating the washer. . In
this case, a servicer would need to take a look at the unit. In this case, you
will need a service center to look at your unit. For service assistance, please
visit our website at us.lgservice.com Click on "Service Center". Enter your
zipcode and product type. Click search.
In the event that you cannot find a service center, please call 1-800-243-0000
for assistance. There, an agent will be able to provide you with an Authorized
LG Service Center in your area.
Please have your model and serial number available along with your zip code when
you call. If you have a customer service issue, please let the agent know and
they will set up a customer service file for you. If your unit is under the
factory warranty, your purchase receipt will validate the warranty.
Business hours are 24 hours a day, 7 days a week.
I have taken the liberty of providing some hints and additional information that
may be helpful concerning your LG washer.
If you must use a regular detergent, you will only need to use 1/2-1/3 the
amount you would normally use in a conventional top-loading machine. However,
the HE and the conventional detergents are different formulae, and your machine
will not perform as efficiently or effectively. Using half the required amount
of regular detergent will
give half the cleaning performance. As the new LG washers accept a larger than
usual load, the cleaning performance could be further reduced. In addition to
the reduced cleaning, there will be oversudsing. The excess suds will cause the
washer to stop and rid itself of the suds before continuing its cycle. Getting
rid of the detergent will further reduce cleaning performance.
Using too much detergent can cause a build-up on the outer drum over time, which
can result in mold and even mildew growth in your washer. Should this occur, do
a load of whites on the SANITARY cycle. Use the extra rinse and stain options.
Use NO detergent and use a liquid bleach. This will remove the build-up and any
odors accompanying it. This procedure may need to be repeated a couple of times
depending on the degree of build-up.
The washing time may vary by the amount of laundry, water pressure, water
temperature, and other using conditions.
The 'SenseClean Washing System' has a built-in turbidity sensor that measures
the detergent/suds residue in the water during the rinse and then makes an
adjustment of time and water usage based on the detected residue level.
The machine will detect an imbalance and attempt to correct it. If the imbalance
is detected or if the suds removing program operates, the wash time will be
increased.
A built-in water heater in the washer assures that incoming water is the correct
temperature to optimize cleaning performance. Most laundry detergents must be
activated at certain temperatures to work correctly. We use thermisters
(electronic thermostats that have a high degree of accuracy) to detect incoming
water temperatures. Our 1000-watt heater adjusts the incoming water to ensure
superior thermal action performance.
You won't see a "visible" water level in the window of the unit. The water is
pooled in the inner drum. RollerJets are built into the baffles of the washer.
The holes in the baffle collect water and re-circulate it during the wash. This
increases the mechanical action to achieve best cleaning performance. The
rollers gently move fabrics
along in the wash cycle.
This action aids in reducing the amount of water required for thorough
cleansing. In contrast with a top-loading machine, which always fills the
machine to a precise measured level of water, depending on the size of load you
select (small, medium, large), the LG machine will "sense" the size of the load
and only recirculate a minimal amount of water, thus making it very energy
efficient, efficient in the use of detergents, and extremely efficient in its
water usage.
Forced Water Circulation in the washer pumps water during the wash. It
recirculates it back up and over the laundry to further increase mechanical
action and cleaning performance.
With front loading washers, the door seals so very tightly unlike a conventional
machine, that it is recommended to dry the seal when you are done with your
laundry for the day to prevent an atmosphere where mold and mildew can grow.
To get the best results, sort clothes into loads that can be washed with the
same wash cycle. Different fabrics need to be washed in different ways. Always
sort dark colors from pale colors and whites. Wash separately as dye and lint
transfer can occur causing discoloration of white clothing. If possible, do not
wash heavily soiled items with lightly soiled ones.
Combine large and small items in a load. Load large items first. Large items
should not be more than half the total wash load. Do not wash single items. This
may cause an out-of-balance load. Add one or two similar items.
Hope This help
Good Luck!!!
neo
Posted on Feb 27, 2009
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
App King
  • 55 Answers
SOURCE: LG front load washing machine water leaks with heavy loads
If your water is leaking with heavy loads, the first thing you want to check is the gasket (door boot) attached to the tub. Look for holes or rips in the bellows part(where the water settles) and around where it contacts the door. Any nicks or holes will cause leakage. Also, check the glass dome on the door towards the bottom. If it has dirt or hair buildup on it, it will leak with any pressure on the door.
Posted on Jul 15, 2009
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
My wash machine drum keep banging on side walls when spinning causing very loud noise and vibration
What kind of make and model washer do you have?
Your drum is off balance.
Is this happening with all loads or awkward heavy loads?
If the load is too big or heavy you have to stop the machine and adjust the load.
Can not give more info without knowing more.
Nov 25, 2015 | Washing Machines
Heavy duty super capacity plus
You dont. If it is making noise drum bearings or idler needs replaced
Nov 03, 2013 | Kenmore 24032\24036 Top Load Washer
Knocking from the drum
You really should realize that when clothes get wet, they get heavy. If those heavy clothes are sticking to one place on the drum it will be out of balance and knock at the sides of the washer. If this happens, simply open the door (not when the washer is full of water, of course) and the drum will stop spinning. Just spread the wet stuff around the drum surface and close the door...voila!
Jan 12, 2013 | Electrolux Washing Machines
Heavy mechanical knocking on final spin yet drum rotates freely when turned by hand and at low end drum speeds. Doesn't point towards the bearings. I have noticed that drum appears to be rotating slightly...
The knocking is the drum running out of balance due to the drum shaft being worn or corroded, or a worn bearing, a bearing can fail even though it may not sound noisy
Either way it is assoiated with the drum and entails a complete strip down, trust me on this, I do know what I am talking about.
Dec 03, 2010 | Zanussi FC1200W Front Load Washer
When spin starts - sounds like drum will detach. very load and shakes the whole room.
You have an uneven load in the drum, for example a shoe or something heavy that should not be in the washing.
Apr 28, 2010 | GE WSXH208A Front Load Washer
Certain papers, notably a transfer paper that I have used in other machines and have a lot of, will not stick to the drum properly which causes a 'jam' message: "Open front door, remove paper from drum"....
The paper on the CLC-1180 is held to the Transfer Drum by static attraction. Certain papers or media will not work with machine. One thing you can try is to check the flex the paper. Flex the paper and see which way it has the most flex. If the paper has more flex or bend in the Landscape direction load the paper in the Letter "R" direction, or Portrait direction (letter). If the paper is too stiff it will conform to curvature of the transfer drum and Jam.
Canon does not recommend the use of Transfer Material in the CLC series. Canon does have a recommended Heat Transfer Paper for Fabric item # 6094A082AA that will work with the copier.
Canon does recommend aftermarket transfer paper do the damage possible to the fixing rollers. It's possible you could get a Service Tech to adjust the Attraction charge in the copiers service mode to make this paper work better. The CLC 1100 series this very fussy about paper and some papers will just not work. The newer Canon Color copiers use a Transfer Belt which eliminate the bends and provide a straight through paper path much improving the performance with odd or heavy papers.
Mar 01, 2010 | Canon CLC 1180 Copier
Creda drier drum will not rotate when fully loaded
The belt could be worn or bad or the tension spring is to loose and not keeping enough tension on the belt. When loaded to max belt just slips and doesn't turn the drum.
Dec 16, 2009 | Sewing Machines
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
What causes the tears in the bellow seals on front loaded washers
It’s caused by gradual wear and tear through the vibration of the machine and rotation of the drum. If they are breaking down too often then it may be that your washing detergent mix or use of bleach or how you clean the bellows is weakening the rubber. Also excessive and heavy loads put more stress on the drum and can cause the drum to lurch dramatically from side to side which will end up in causing the bellows to wear / tear.
Oct 06, 2009 | Washing Machines
Only turns with light load
If this is not turning with a heavy load it can be one of or a few different things. The motor may be going bad and cant handle the heavy load or the drum belt may be slipping or the dryer drum wheels where the dryer rides on may be worn out.
If its the wheels the machine will be making a sort of a grinding sound when it runs and the dryer drum will be loose and wobbly inside the machine. The drum wheels and belt are cheapest, probably less than 10 bucks for both.
You will need to remove the front of the machine and remove the drum to get to the wheels and belt. It shouldnt take more than 1/2 hour or so to do this job.
The motor is another thing. 150.00 for the part, hours of labor and electrical connections. Clearly not worth it unless you have access to a cheap parts supplier. Check ebay for appliance parts suppliers. They usually buy up manufacturers surplus parts and sell them for 1/2 of what they originally sold for.
Oct 11, 2008 | Amana ALG331RAW Gas Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
