Question about Refrigerators
Just wondering how much room should be around the side by side ?
I have a a spot for a frig that is 33 in deep and 33in wide and that is the exact demensions of the frig I want but should there be more room than that for good and safe operation?
    President:
  • 1,214 Answers
Sufficient room is there for safe operation. All ventilation flow's through from front to back, back to the front.
Posted on Jan 25, 2009
How do you put a bagger on a 33in wide cut troybuilt lawnmower
www.troybilt.com/equipment/troybilt/ownercenter
Suggest getting a manual.
Oct 28, 2014 | Garden
What is size of freezer that is 64" tall X 33" wide x 24" deep?
64 inches times 33 inches times 24 inches is 50688 cubic inches.
One foot is 12 inches, so one cubic foot is 12 inches times 12 inches times 12 inches or 1728 cubic inches.
50688 cubic inches divided by 1728 cubic inches per cubic foot is about 29.3 cubic feet.
Apr 25, 2014 | Office Equipment & Supplies
Spot Bot leaves mold rings
Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
What is the cubic feet measurement for a GE Model TBX18 refrigerator? Also, what is its width and height?
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including
TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
Mar 18, 2011 | Refrigerators
Hi, I am going to purchase a 12000 btu 1.5Hp portable aircondioner unit for my living room of around 42 m^2 (7 metres wide and 6 metres in length). I am wondering if this unit is suitable for the room?...
Hello =D
12000 BTU will cool approximately 450 to 550 square feet. That's around 137 to 167 m/2.
Unless your name is Beelzebub and the room your trying to cool is really really really really south (or in this case down). =D <that's not two horns is it? ";-} That should be more then enough to keep everything cool.
Good luck and I hope this helps.
Dec 27, 2009 | Heating & Cooling
Frig gets too cold freezer works good
I had the same problem. I have the side by side Profile Artica. The problem was a broken damper. It allows the cold air in from the freezer side. With it broken, there was a steady flow of freezer air coming into the frig side. It was easy to fix. I ordered the part (damper/fan assemble) for around $100. While searching for a solution, it seems that this is a common problem. Unfortunately, I received a wide range of incorrect solutions to the problem which could have cost me a lot of money. I hope this helps!
Jun 19, 2009 | GE Profile PFS22 33" Artica French Door...
Damaging vibration over 70mph
If this started after the rear wheel replacement recheck the allinement of the wheel it could have slipped.Then check condition of the drive belt for hard spots or missing teeth.If all this checks out have the wheels balanced and check steering head tension
Jan 23, 2009 | 2000 Harley Davidson FXDWG Dyna Wide Glide
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
