Question about Bowflex Treadclimber
Just bought a Treadclimber TC10 error code H07.
I started walking on it and a rattling noise started. It would speed up then down then it quit H07 appeared on the screen..
3 Suggested Answers
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
  • 3 Answers
SOURCE: i have a treadclimber 1000 and it will not start.
call bowflex and get a return authorization fast
Posted on Jul 20, 2009
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Makes a loud rubbing noise on one side
To be honest with you, these could be symptoms of a few different problems. Here are the most common ones and what it possibly sounds like:
1) It could be that the front roller has dislodged itself from the roller pulley. In other words, the motor keeps turning, and when you step on the walk belt, the pulley (the one with the small rubber belt) keeps turning, but the roller stops. This can cause grinding noises, and the pulley to "skid" the black belt, which can account for the black dust. You can usually tell this is the problem when it runs fine with nobody on it, but when you step on it, it grinds
2) It could also be that the walk belt is rubbing on the sides of the deck and/or side rails. This happens when the belt shifts over from the center. It would definitely sound like a grinding noise, and the black dust could be from the walk belt particles wearing down due to the rubbing.
3) It could also be the drive motor brushes. Let me explain. The motor has two small blocks on either side of it (inside the metal casing). Those two blocks actually carry electricity into the spinning part of the motor (called an armature). They actually make contact with the armature at all times while it spins. Those "small blocks" are made of a graphite (what pencil lead is made of). Well, with so much spinning, and so much contact from the armature, those things grind down with time. They sometimes grind down until they are stubs only. Then they start grinding. The powder in this case would be the brush graphite piling up (this would often be shiny dust, and is a dark grayish).
4) The grinding could also be roller bearings going bad.
**For #3, and 4 above, you have but to remove the small belt that attaches to the motor (rubber, black, and small attached to pulleys), and let the treadmill run for a few seconds by itself. You may get a "speed error code' after the treadmill does not detect speed, but at least you'll know if the grinding is coming from the motor. If it runs super quiet, even for a few seconds, then you know it may be #1, 2, or 4 above.
These are the most common issues based on your symptoms.
Mar 16, 2014 | Bowflex TreadClimber TC5000
Ask
there are both on same setting. test the shock for faulty and replace. download the manual from www. fitness.manualsonline.com and fix it. section troubleshooting
God bless you
Jun 16, 2013 | Bowflex TreadClimber TC10
HOW TO CHANGE MY TREADCLIMBER TC10 WALKING BELTS
Bowflex has a service manual for the TC10 that includes walking belt replacement instructions, If you call customer service they should be able to email the whole manual or just the belt replacement steps.
May 07, 2013 | Bowflex TC1000 Treadclimber
Bowflex error code H05
I recommend that you call the factory. They have bad disegned with the hardware, they can exchange the old board by new ones without cost.
Reach them and explain the problem. go to www.bowflex.com
God bless you
Sep 07, 2012 | Bowflex Treadclimber
Our TC 1000 stopped. We get the Error Code E1 when we try to turn it on. There is no sound or any movement. I don't know where to start. Help.
hi
ur treadmills speed sensor have some problem. pullout it clean it and then refix it. also check its white connector , is its connection is proper or not. if the sensor found faulty replace it.
ok
Dec 20, 2010 | Bowflex TC1000 Treadclimber
After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
Jul 11, 2009 | Bowflex Treadclimber
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Bowflex Treadclimber Logo
106 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
