Question about Nintendo DS Lite Console
Ds lite doesn't switch on, yellow light flashes once
My Son and my Dad both have a ds lite each with the same problem, they switched off, we assumed they needed charging but when we plug the charger inthe yellow light flashes foffr a split second,almost as if the battery is fully charged, we have swapped the battery and tried chargers. wehave been told it may be a fuse but we are a little reluctant to open them up without knowing if it would be a fuse. Does this sound like it could be the fuse or could it be something else? How easy is the fuse to locate and replace?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
As far as I know there is no fuse in the DS. Try booting them without any games in them. Also, try checking the batteries for water damage. There should be a small white label about 1/8th inch square on it. If the label has pink dots then there was no water damage however if there arent any dots its very possible that it could be water damage
Posted on Jan 25, 2009
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
Why is yellow light blinking on top of unit?
Per the DS1 manual the yellow light relates to the SafeSense feature. A toggle switch under the deck is the SafeSense override switch. The override switch deactivates the SafeSense feature so that you may clear a paper jam. When the switch is in the override (left) position, the SafeSense yellow light will flash and the SafeSense feature will not function. Once the paper is cleared, reset the SafeSense override switch to the right position. The SafeSense yellow light turns on when you touch or are too close to the paper insert opening.
Jan 18, 2011 | Fellowes DS-1 Shredder
Ds lite wont power on the green light is on, any suggestions of a diy repair
The wireless board on the main motherboard must be checked to see if it has come loose. This presents as the charge orabge lamp works with the charger pluged in, On green light comes on when power switch pushed once and stays on without flashing. Pushing the power switch once more puts the green light out. Bruce
May 08, 2010 | Nintendo DS Lite Console
NDS lite has the power(green lite flashes), but screens wont lit
When you switch the DS lite on you should notice that one of the screens flashes... if thats correct then the screen that doesn't flash is the one that will need replacing which, I would assume is the upper screen as judging by what you say has a damaged ribbon.
Regards,
SOD69
Feb 10, 2010 | Nintendo DS Lite Console
DS switches off straight after switchig on
make sure the battery card isnt loose, to do this, remove it from the counsil, use WING tip'd screwdriver
Dec 27, 2009 | Nintendo DS Lite Console
My son dropped his ds lite. When plugged in the light turns green. When you try to turn it on the top screen flashes then goes off
The DS lite is easily broken when it is dropped keep trying it or ask for a repair where u bought the ds
Jul 01, 2009 | Nintendo DS Lite Console
When plugging power to the DS lite the led flashes orange once
I think if the orange light flashes once it means it has a full charge.
Mar 18, 2009 | Nintendo DS Lite
Nintendo ds lite flashing top screen
i had a similar problem to this, i would check the connector strap in between the two screens if it is just one pin out this can happen
Jan 25, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
679 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
