Question about Toshiba Satellite L675-S7044 Notebook
How to connect a toshiba satellite L675 to a tv using HDMI cable
  • 3 more comments
  • tchemeon
    tchemeon Jan 18, 2013
    I have the laptop connected to the TV with an HDMI cable that works just fine with my HP laptop.
  • tchemeon
    If I hold down the windows logo key and press the P key to select the TV connection I get a message back that it cannot find the device.
  • Chad Britt Jan 18, 2013
    Why are you trying to switch with Windows P? Does you TV not show what the Laptop is showing just a few seconds after you connect to your TV with you HDMI?
  • tchemeon
    No, that's why I tried this method.
  • tchemeon
    My HP laptop works just fine as you say. Just connect and it works, however the Toshiba will not make the connection.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
If you TV has HDMI connections. All you need is a HDMI cable. Hook the HDMI cable into the laptop and into the TV. Turn the TV on and go to that HDMI connection on the TV. It will show everything on the laptop on the TV. Videos, Documents, and anything else.
Posted on Jan 18, 2013
    Why are you trying to switch to the TV with Windows P? If you hooked up the laptop does it not display right away?
3 Suggested Answers
Current009
  • 135 Answers
SOURCE: can I connect my Toshiba NB 205 to my TV to watch
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
Posted on Jun 01, 2010
  • 107 Answers
SOURCE: Toshiba satellite L675 freezes after
Boot the computer into "Safe Mode".
To boot PC into Safe Mode follow these steps:
1. Turn the computer on or Restart the computer
2. Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
3. Ensure that the Safe mode option is selected, not Repair Your Computer
4. Press Enter. The computer then begins to start in Safe mode.
5. When you are finished with troubleshooting, close all programs and restart the computer as you normally would
If the computer boots into Safe Mode you can try disabling Startup Programs, one of these might be causing your computer to freeze. To do this follow these steps:
1 Press Start. Type msconfig into the search bar and press Enter. For XP, click on Run and type msconfig there.
Posted on Mar 30, 2011
Why won't my Toshiba Satellite L655 laptop connect trough HDMI anymore?
Try pressing the appropriate function button to change the screen from internal to external. Possibly F4?
May 15, 2014 | Toshiba Satellite L655-S5101 Laptop
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
What cable do i need to plug a toshiba satellite L300D into a tv
depend on yr tv and laptop, normaly use hdmi cable to connect laptop and tv
Feb 19, 2011 | Toshiba Satellite Pro L300 Notebook
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
How do i connect my Toshiba Satellite U505-S2950 to my hd tv ? I have an HDMI cable but my lap top has no port for it.
Your laptop has a vga port, use an vga male to HDMI female adapter to connect the two with an HDMI cable. There are adapters available at a company called "Cables to Go" below is their web site.
https://www.cablestogo.com/categories.asp?cat_id=100
Jan 13, 2010 | Toshiba Satellite U505-S2940 Notebook
Connected A300 Satellite to HDMI TV worked perfectly. Watched movie using VLC. Can't get it to work again. Tried HDMI Control and says only with tv that supports HDMI. TV is definately HDMI.
power off your pc completely and remove hdmi cable. with the tv on, plug the hdmi cable back into your pc and power it up. tv should be recognized.
Jan 06, 2010 | Toshiba Satellite A300-0CF035 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Tv model 42H82
Hi Ranger01,
If you satellite receiver is HD, connect it to your audio system with Component or HDMI (preferred) cable. If your receiver only passes through HDMI, you will have to use an optical toslink cable for digital audio.Have the monitor out (HDMI or Component) go to one of your tv inputs. Set your TV to Mute and program the satellite box to out put audio through the appropriate cable (HDMI, component or Toslink optical). More details as to brand/HD tv or not will help me give you a more specific answer.
Hope this helps,
Regards,
Machaan
May 31, 2008 | Toshiba Satellite P35-S611 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Open Questions:
Toshiba Satellite L675-S7044 Notebook Logo
643 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
