Bauhn lcd tv model AX-42FD1 sound and no picture
Picture was intermittent before going all togeather
  • 41 Answers
SOURCE: sound problems
Sounds like there is a bad solder connection inside the set and needs to be looked at by a tech. The Flashing LED usually will be a code for the tech to send him in the right direction as to the problem. Try counting how many times it flashes and call them or manurfacture. hope this helps
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: No picture on a Westinghouse lcd tv model ltv-20v4
I had this problem with these tv`s. The problem actually lies with the power supply inside the unit. Some of the units i`ve seen have 2 blown capacitors on the power supply (C7 and C6) replacing these works. On others, the capacitors as well as a few transistors (Q8 - Q1) are blown. But on all the sets i have seen with this problem, changing the above components restores full functionality to the system.
Posted on Jul 20, 2009
  • 78 Answers
SOURCE: my LCD TV has blacked out.
this could be one of 2 things. the sound is still working, which indicates that the internal power circuitry is still functional. a power surge / spike couldve cause damage to the video side, or the internal bulb could be burning out. this is something that you'll want to find about about repairing through the manufacturer. you can purchase replacement bulbs for relatively cheap, but finding a tv repair shop that CAN and WILL work on LCD or plasma tvs are kinda rare. people tend to stray from the things that they dont understand, but most shops will attempt to repair it even if they dont know anything about it. which would mean taking the chance of finishing off your tv completely. my advice: call the manufacturer and inquire about repairs through them, or buy another tv.....obviously the first option is WAY cheaper.
Posted on Sep 24, 2009
SOURCE: My 32HL57 model tv has sound but no picture?
en francais
le modul est fixé sur l'ecran
sur ce modul verifier si vous avez 3.3 volt (trois regulatuer avec un test point) si vous n'avez pas 3.3 verifier les deux fusibles F1 et F2
F1 devrais etre ouvert ....
bonne tv ;)
module is fixed on the screen
this modul check if you have 3.3 volts (three regulatuer with a test point) if you do not have 3.3 Check both fuses F1 and F2
F1 should be open ....
good tv;)
Posted on Oct 05, 2009
dave1645
  • 834 Answers
SOURCE: have a 40 inch samsung lcd tv, the screen flashes
you either have a bad bulb or a losse bulb in the lcd panel a good reapir shop[ can fix that by reseating the bulb or replaceing them
Posted on Nov 20, 2009
Bauhn 58" sound good, picture comes and goes - irregularly?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 11, 2017 | Televison & Video
Will a sansei urc-501a remote have a code for a bauhn tv model actios fullhd/led/lcd atv40-014
One way to find out is to use the code search function in your Sansui (?) remote to find something that will handle your Bauhn TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Sep 16, 2016 | Televison & Video
Remote code for Bauhn ATV-BA32DV2
bauhn p v r setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... bauhn universal remote control tv but i had vivo tv how ican set up that The universal ... ATV-BA32DV2, have done initial setup, but screen says have to scan ...
Remote code for BAUHN TV model ATV-19HED - TVs - Home theatre ...
forums.whirlpool.net.au > Home theatre > TVs
WhirlpoolDec 14, 2014 - I've mislaid the remote for this TV and I was wondering if anybody new how I could get hold of BAUHN remote IR codes. I've looked everywhere ... 32" (81CM) HD LED LCD TV $222
May 29, 2014
Bauhn 24" Full HD LED LCD TV with DVD
Jan 12, 2013
More results from forums.whirlpool.net.au
[PDF]32" (81cm) HD LED LCD TV
Feb 03, 2016 | Televison & Video
Bauhn 58cm F H DEfinition LED LCD TV with in built DVD Model MD21067
Check its sound settings. If audio is muted, there will be no sound output. If its OK, and not muted, check its speaker/s. If found OK, check and replace damaged component/s at its audio output stage circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 19, 2014 | Televison & Video
My bauhn TV screen stopped working. DVD plays sound but no picture. Can the TV be reset or rebooted
You can try unplugging the units--no picture often means the DVD has a dirty or failed optical unit.
Aug 30, 2012 | Televison & Video
Picture shows for 1 sec when switching on TV, and then screen goes black on my Sansui TFT SV-2010 LCD Monitor
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like Shopjimmy.com,Ebay.com to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
Oct 03, 2011 | Sansui HDLCD3210 32 in. LCD TV
Tv: why do I only get sound when I turn the TV on?
Exactly i do no the problem in the video section.
Feb 19, 2008 | Proscan 32LA30Q Television
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
