Question about GE PSA1201RSS Microwave Ovens
How to replace door handle psa1201rss - GE PSA1201RSS Microwave Ovens
Door handle broken. I want to find a replacement handle without replacing entire door.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance.
NOTE: I would need a MODEL NUMBER in order to determine if your appliance repair parts list the door as an entire assembly, or if you can purchase the handle separately. You can also view the websites I have listed in the link provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
May 05, 2011 | Microwave Ovens
The door handle on the microwave oven has broke, How do I replace it I have a replacement handle
If you have any questions, please post back and let me know. I hope this helps you.
Dec 22, 2010 | Microwave Ovens
Door handle has broken loose at bottom of handle and needs to be replaced. How can this be accomplished?
Nov 10, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace just the door handle on a Maytag Microwave (Model No. MMV4205BAS). All I've seen online for parts is a complete new door for anywhere from $220 to $300. Surely there is a cheaper...
The handles run about $25-35 here.
Here are the part numbers & descriptions:
W10279351 Black handle
W10279353 White handle
W10279355 Bisque handle
Sep 07, 2010 | Maytag MMV4205 Microwave Oven
Replace door handle
Aug 23, 2010 | General Electric Advantium 120 Microwave...
Replace handle on whirpool microwave
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
If you have not purchased a new handle yet, the part number is 4359474 (Black) and 4359473 (White) and costs about $30.
Aug 12, 2010 | Whirlpool MH7135XE Microwave Oven
PLASTIC AROUNG SCREW POINTS HAVE BROKEN OFF AT BOTH TOP AND BOTTOM. HANDLE IS 9 3/4 IN LENGTH AND FITS FLUSH AGAINST DOOR (DOES NOT HAVE A SMALL PART THAT STICKS INTO DOOR . MODEL # J VM230WL01 WANT TO...
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. The part number for the model number you provided is WB15X322. You can view an exploded view of your microwave door here:
http://pcappliancerepair.com/model-display.php
Apr 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I am trying to replace the door handle. How to I
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, and you haven't purchased a replacement handle yet, the part numbers are WB15X10119 and WB15X10120. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
Dec 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
GE PSA1201RSS Microwave Ovens Logo
85 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
