Question about LG 42LC2D 42 in. LCD HDTV
Jmb lcd speaker probs
Bad crackling sound coming from speakers
  • 92 Answers
SOURCE: Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Posted on Oct 31, 2007
rlamkin
  • 44 Answers
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Posted on Jul 03, 2008
welcomejee
  • 10594 Answers
SOURCE: lcd speakers
I suggest to unplug surround and sub woofer so you will get sound from front speakers only.
Posted on Dec 12, 2008
  • 167 Answers
SOURCE: crackling sound from speakers, intermittent,
If these speakers are internal to the TV, chances are an internal component is getting noisy -- probably a capacitor -- and will eventually need replacement. That's not something you can do yourself. It's also possible there's a loose connection or a noisy volume control, but that's less likely, and again, would require a qualified serviceman.
If the speakers are external - that is, you've plugged them into the set -- check the connections at the set and at the speaker to make sure they're not corroded and are firmly seated. Sometimes just unplugging and replugging them a couple of times rubs off enough corrosion to solve the problem. Also wiggle the wires close to the connectors on the cables. If that causes the crackle, replace the cables.
Posted on Oct 04, 2010
ladywinn
  • 5138 Answers
SOURCE: My 32"lcd tv crackles very
Look for Bad Capacitors on power supply board, they will be vented or swollen on Top.
Posted on May 31, 2011
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
LGTV 42LCD - LOUD CRACKLING SOUND ON START UP -
Either your main pcb has a defective auido circuit or speakers are bad. Doubt it is the speakers or it would do it all the time.
Mar 20, 2013 | LG 42LC2D 42 in. LCD HDTV
My hp mini sounds distortd when i play music like a crackling sound
update the sound drivers. most of the time when crackling happens it comes from bad drivers. if that does not solve it, then check the levels of the speakers. if all of that is fine then you may have blown your speakers from playing them excessively loud
Oct 29, 2010 | Computers & Internet
Toshiba 42H81 speaker crackle
It could be the board or the speakers itself.
Check see if ur air tv have any crackles?
If not u can rule it out the speakers.
Tries it with diffrent cables,see what happen.
The prob.still there it ur electronic board.
Aug 27, 2009 | Toshiba 42H81 42" Rear Projection...
Crackling noise from subwoofer!
If ayou have a system with speakers that works and a different set is crackling
the set that crackles is to be determined the bad set. Cones dry up a bad assembley just coinsidents having a bad set of speakers. It is an AUDIO problem not a computer problem
Jul 27, 2009 | Acer 90.00012.30B Computer Speakers
No sound coming out of speakers
A quick way to check your speakers is to put the contacts from a 9 volt battery to the positive and negative speaker wires (briefly). You should hear a crackle of some sort if the speakers are functioning. If there is no crackle, speakers are bad / if there is a crackle, your head unit must have a problem.
Jan 22, 2009 | Kenwood VR-509 Receiver
Sound prob
Let me know what the Type Numeric Number and Model Number on the bottom of the laptop is. I can look on IBM website and see where the hard drive is in located to the speaker. It has happen on some HP and Toshiba I know from experience where the hard drive causes the speakers to crackle. Not sure why, maybe not enough shielding. The type has 4 Numeric Characters and the Model has 3 Alpha/Numeric Characters.
Let me know
comier957
Aug 10, 2008 | IBM ThinkPad R40 Notebook
Crackling Sound
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
After a while the system starts crackling and eventually sound deteriorates to thundering in speakers
Hi, I have exactly the same prob and I belive that it is in the amp module?! I am going to take mine in for repair as my other sony HT amp has just give up the ghost, (STR-DE435), it has a protector prob and is probably not worth repairing, although it is a great amp. If anyone knows the solution to this prob it would be great to hear it!!!
Nov 21, 2006 | Sony DAV-SA30 System
LG 42LC2D 42 in. LCD HDTV Logo
22 people viewed this question
Computer Repairing
Computer Repairing
