Question about Dell Inspiron E1705 Notebook
E1705 won't turn on
I bumped the power cord against the chair and the power went out. Now it won't turn back on. There's just a on battery light that will show up but not stay on. Help
  • 3 Answers
I9 dont know but i have the same problem with my sony viao laptop i opened it up and the mopther bord ro the on switch had disconected so i fixed it back and it worked... you can either do this or get someone eles to do it as opening it up will exspire you warrenty on it.
Posted on Jan 25, 2009
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Won't power on
Hi friends,
please check the dc adapter voltage,And battery also.
Ensure the adapter light is gong on, if ok condition, please measure the voltage.
Voltage will be E1705 DC Car Adapter (20V/6A 120Watts) check it.If not work please purchase from
http://www.amazon.com/Adapter-Inspiron-Latitude-Precision-Workstation/dp/B002BH8XAO
http://www.amazon.com/Dell-INSPIRON-Latitude-PA-10-Original/dp/B0034JWXBI
For battery
http://www.amazon.com/Lithium-Ion-battery-Dell-Inspiron-E1505/dp/B001E41PHI
Hope it will help you.
Dec 17, 2010 | Dell Inspiron E1705 Notebook
How do I charge the Hoveround mpv 4? I plugged the charger into the chair and plugged the cord into the wall using an extension cord. The red light on the box turns red when in the "on" position but the...
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Jun 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
I bumped against a chair
Try different slots. or on a other computer.
You could also try to open it a see if the internal drive moved out of place .. only try if you know what ur doing.
Feb 21, 2010 | Fanner Masscool UHB-358B 3.5 External Hard...
Power indicator light blinking
it looks like the battery is defective. try reseat the battery while the power cord plug in to see if that help. if you remove the battery and leave the power cord plug in, the battery symbol indicator light will turn off. Time to order a replacement battery.
Nov 24, 2008 | Dell Inspiron E1705 Notebook
E1705 Wont power on, indicator lights blink for few seconds
Kinldy folloow the steps given , in the following link to pin point the exact cause of failure. I suspect the motherboard has gone bad and it would require a replacement.
http://tinyurl.com/65uofc
Do let me know if you need furthur help
Thanks
Proton
Jun 29, 2008 | Dell Inspiron E1705 Notebook
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
May 29, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Dell Inspiron E1705 Notebook Logo
697 people viewed this question
Alun Cox
