Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
I have a hotpoint aquarius wd640 my boiler has broke so could you tell me if my washer drier is a hot or cold water fill
  • Hotpoint Master
  • 3,463 Answers
Most washers made today, are cold fill only, best way to check is look at rear of washer, and if there is only one hose, then it is cold fill only, if 2 hoses, then hot and cold fill..
So if your boiler is not working, then it should be o/k to use if cold fill only.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
Machine fills with water even when no power on
This is symptomatic of a stuck-open/malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Turn of one of the supplies overnight to see which one is in error- that is if yours is hot and cold!
Then a service call, I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 06, 2011 | Hotpoint Aquarius WD640 Front Load...
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wf 640
You cant seal off the inlet, but you can get a Y adapter, its a hose that splits into 2 outlets. They are most often used to hook up steam dryers but will work for wha you need, this will allow you to use it but it will not get the best cleaning results
Jul 19, 2009 | Hotpoint Aquarius WD640 Front Load...
Aquarius wash and dryer
can u please tell me what the problem is?
Jun 23, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Inlet hose leaking a top branch
There are 2 versions of the Hotpoint WD640, a cold fill only version, and a hot and cold fill version..
From your question, I conclude you have the hot and cold fill version, which requires a hot and cold fill supply..
I do not understand what you mean by leaking from top banch, perhaps you can clarify.
Thankyou.
Feb 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Drier not working
take top off. you will see drier manifold going across top of machine with stats mounted on it. one or more of these stats is resetteble ie has a little button in the middle. press to reset. some hotpoint have a thermal fuse mounted on the manifold so if present, check this for continuity as well. with top still off, put on dry and check fan working as well.
if you get it going and fault reoccurs, then there is a blockage in the drier duct
Jun 22, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
139 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
