Question about Kenwood Food Mixers
Food Processor stopped spinning
In the middle of processing (grating cheese) it suddenly stopped spinning. The engine's pitch changed and there was a 'squeak'. The spindle no longer revolves. The engine comes on and sounds normal but nothing happens
  • mumfie68 Jan 25, 2009
    Does that mean it's knackered or can I fix it?
  • 142 Answers
Sounds like you may have stripped the gear that drives , or thrown teeth off the cog.
Posted on Jan 25, 2009
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/fp-12dc.pdf Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
My Hobart H-600 commercial dough mixer shut off in the middle of grating cheese now it will not turn back on
Google perhaps a fuse is blown something was to heavy or something was under tension to the power supply that so the machine did not get the required voltage by too much taxation by other devices on the power line group
Oct 15, 2015 | Hobart Food Mixers
Making a high pitch squeal
the unit needs service, i mean oiled and greased, it rubbing metal to metal and you are going to burn up the unit
Sep 17, 2015 | Robot Coupe R301 - Commercial Food...
Motor spins but blade doesn't
If there is a shaft sleeve available from Kitchen Aid you will need to replace that and most likely the chopping blade if there is any damage up inside it.
May 01, 2013 | KitchenAid 3.5-Cup Food Chopper KFC3511
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
Overheat after grating cheese, make an awful noise to top it up , have i burned the gears ?
You are putting too much pressure and overloading (motor) the Mixer. Specially if you run it for long time.
Grating cheese is hard on mixers.
Let it rest and turn it back on, ON LOW and little or no load.
Jan 14, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
Can you use a spiral dough hook when the mkixer runs in reverse?
You can but the dough would ride down towards the bowl instead of up and your mix would not turn out properly.What kind of mixer do you have?i'm a hobart tech and repair these mixers often.Let me know.
Nov 04, 2009 | Hobart H600 Stand Mixer
Kitchenaid artisan mixer does not turn the blade at low speeds
If it is the worm gear then the planetary will stop turning when there is a load on the paddle but the motor will continue to run at the speed you set it at. I'd be checking the carbon brushes, checking that the field assembly has not loosened up a bit and then I would see if the speed control plate adjustment screws are loose. I'd then reset the speed and see if it stays as it should be.
Sep 24, 2017 | KitchenAid K45SS Classic Stand Mixer
My handmixer suddenly stopped working while i was
sounds like the beater is not all the way in or it broke a gear
Mar 12, 2009 | Braun M880 MultiMix Hand Mixer
Food Mixers Logo
144 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
jason
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
