Question about Cycling
Carrera cartridge system heatset - Cycling
Fuel pump for porsche carrera 1985
If you are looking for a replacement pump I would recomend 1985 Porsche 911 Carrera Coupe Fuel System Page 3
They also have a great forum to ask questions with thousands of members willing to help you.
Jan 25, 2014 | 1985 Porsche 911
Lost screw holding in the lens for a Carrera 6
just go to an optichons like exspres sory but i can not spel to go but this shuod solve it for you
Jan 22, 2013 | Carrera 6 Sunglasses
I need a instruction manual for binatone carrera sat nav
  • Just look it up on the internet... see below [PDF] User Guide B350 - Binatone www.binatonetelecom.com/.../binatone/.../gps.../b350_user_guide.pd... You +1'd this publicly. UndoFile Format: PDF/Adobe Acrobat - Quick View
    The Global Positioning System (GPS) is a satellite based system that provides location ... operation of you Binatone Carrera Personal Navigation Device (PND). Using Your ..... This manual leads you through the main features of the system.
  • Jun 07, 2012 | GPS
    How to up date my binatone carrera stat nav
    Anyone with a Binatone satellite navigation system featuring UK and Ireland maps can now easily update to Western European coverage by contacting the Binatone helpline on 0845 345 9677. The extended maps will be provided on a 2Gb SD card at a cost of £39.99
    Jan 08, 2011 | Toymax Binatone Carrera X350 Car GPS...
    I PORSCHE CDR 22 CD ERROR
    Hi
    I had a similar problem with PCM and I reboot the system by pressing 148 at the same time.Now works fine.
    Nikos
    Feb 21, 2010 | 2003 Porsche 911 Carrera
    I want to replace the car radio in a 2000 porsche carrera .question is what will happen if i disconnect the wiring . will the car sill operate correctly
    Either way it goes if you have the system installed into your car there should be no problems with the rest of the car. I know that some dealerships try to scare you in putting in a custom stereo system by sayingthat it could mess up your car. It can only mess up your car if you do not know what you are doing.
    Mar 01, 2009 | 2000 Porsche 911 Carrera
    Car won't start, 2000 prsche carrera 911
    Start by squirting a little fuel into the throttle body and then crank it and see if it fires up .. if so its a fuel problem if not its going to be something in the electrical. holler if you need more thanks Jerry
    Jan 30, 2009 | 1998 Porsche 911 Carrera
    Car won't start
    Let me know, I am having the same problem.
    Code for the navigation system
    you should have got a code card with the car giving you the radio sat nav code etc if not off to the dealer ship you go
    Jul 25, 2008 | 1999 Porsche 911 Carrera
    Cycling Logo
    37 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    John Egan
    John Egan
    Are you a Cycling Expert? Answer questions, earn points and help others
