Question about Generic Canon Color ImageRUNNER C2880/C3380/C3380i Compatible Magenta Laser To
ALIGN PRINTER HEAD ON CANON iR C2880 - Generic Canon Color ImageRUNNER C2880/C3380/C3380i Compatible Magenta Laser To
Error code on display E0000045-0000
Canon imageRUNNER iR C2880 Color Copierchange the drum unit, or try to dismantle it and clean but these is not recommended.
Aug 23, 2011 | Canon imageRUNNER iR C2880 Color Copier
When printing the printer ( Canon iR C2880) leaves a line devoid of colour running down the pages. how do I solve this or at least do you know what the cause of the problem is?
The problem is probably the drum unit.Try to take out the drum unit and look at the drum.Normaly the color of the drum should be all the same across the drum,but if there is brown lines around the drum thats mean it is tiem to change the drum unit.
Oct 20, 2010 | Canon imageRUNNER iR C2880 Color Copier
Reset/change Remote UI Name and Password on iR C2880
I think that username is: admin, and pass: 0000 or 12345. If that doesnt helps you wrote on emma.servis@gmail.com for service manual.
Jul 29, 2010 | Canon imageRUNNER iR C2880 Color Copier
We have a Canon C2880 and it has started to print blank pages for no apparent reason. Toner cartridges are OK.
You need to check the laser shutter and transfer bias. Best solution would be to call service.
Unable to scan from Canon IR C2880 to computer desktop. Looking for manual for specs.
got to canon.usa.com and download the user manual. or go to google.com and type in User manula for the canon ir c2880 copier
Jul 12, 2010 | Canon imageRUNNER iR C2880 Color Copier
How do I get to the drum cartridges on our Canon IR C2880?
open front door remove clip on cover to righthand top push lever in and right hand lower door will pop open remove 2 screw 1 top left 1 top right release black handle and the whole assyembly draws out press button on top and lift up there is a little black support arm to stop it falling down unlock the drum you want to change and remove or just call the engineer if you have a service contract?
Nov 16, 2009 | Canon imageRUNNER iR C2880 Color Copier
C2880 tray 1 lifter
pull out tray see if there is paper stuck in side were the tray slides
Oct 23, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Generic Canon Color ImageRUNNER C2880/C3380/C3380i Compatible Magenta Laser To Logo
53 people viewed this question
Top Generic Office Equipment & Supplies Experts
EE Eddie
Gilbert Ruiz
Tom Chichester
Are you a Generic Office Equipment and Supply Expert? Answer questions, earn points and help others
