Question about RCA F32450 32" TV
Tv switching back and forth from three seperate channels, cant get it to stop on any!
As soon as we turn it on, it is already switching from channel 3 to 4 to 9 to SVID1. Can't get it to stop on one or the other. Please help! Thank you for your time!
  • 398 Answers
The only thing I know of that can do what you are seeing is if something has spilled into the set and has contaminated the pushbuttons under the volume/channel buttons. If the Channel Up pushbutton has fluid in and around it then it can conduct and the microprocessor thinks you are telling it to go up through the channels. The only way to fix that would be to disassemble the set and pull out the PC board which has the pushbuttons on it and clean or replace them. If you do not have experience working inside TV's then allow a qualified tech to handle it for you.
Posted on Jul 13, 2007
SOURCE:
Channel keeps going up when turned on
Dirt/dust in remote or buttons on TV?
Apr 01, 2014 | Emerson lc220em1
I cant get channel three to appear on my tv, to view the cable box channels. Please help I need to reprogram the channels.
You could go to the back of the cable box and change channel from 3 to 4 and use tv on channel 4
Oct 31, 2010 | JVC AV-32260 32" TV
Hi problems seting up vcr to tv ,cant get a good picture through video and channel 3 on tv losses picture when video is turned on
there should be a switch in the back of the vcr to change to broadcast channel.
either ch3 or ch 4
switch to channel 3 and test.
then switch to ch 4 and test
make sure the tv you are attaching to is ON channel 3 or 4
Oct 12, 2009 | Samsung Televison & Video
WHY DO I HAVE TO PUT MY TV ON CHANNEL THREE TO WHATCH A MOVIE
Both previous solutions are correct, but there may be another step. Sometimes the switches are hard to see because they are small and hide near the antenna in and out jacks. But some newer VCR's don't have a selector switch at all. To choose between channel 3 and channel 4 output, you need to use the VCR's setup menu. So if you can't find a switch like the other posters mentioned, check the VCR setup menu for an output channel selection. Then, as previously mentioned, make sure that the VCR output channel is added to your TV's channel lineup.
If you find a solution not exactly what you need, or not clear enough, please post a followup before giving negative ratings (thanks for trying or not appropriate). While those of us who take time to answer questions and try to help here don't get paid, we are more likely to be taken seriously if our ratings stay up. At the very least, both of the previous solutions should have been ranked helpful, because they are correct and should have given you the advice you needed.
Oh, one last thing: In posting, using all capital letters makes it hard to read, and is the equivalent of shouting. Please turn off the caps lock key. Thanks!
Mar 05, 2009 | Daewoo DTQ-20N3FC 20" TV
I installed the converter box on channel 3 instead of channel 4
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Jan 13, 2009 | Televison & Video
I have a jvc tv model av27530. Disconnected cable box b/c going
You probably have to find your original remote to the set and go through setup in your menu. On most sets, there will be a menu item which will allow you to switch from Cable mode to Air mode. If you have no Cable connected, then you must set tuner in Air mode.
If you are using an external device to run on channel three, then try this:
Make sure device (rather it's a vcr or game console), is hooked up to your Antenna Input connector. Also, some of these devices will have a small hidden switch on back that says 3 and 4. Move the switch to 3 position. Turn on device. Go into TV menu and do a Channel scan. This should auto program any device hooked up to the TV antenna input jack to channel three.
Keep in mind that you may not receive anything by Feburary of this year without an HD converter box to tune in channels with and outdoor antenna.
Jan 09, 2009 | JVC AV-27530 27" TV
TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Dec 05, 2008 | LG 32LG40 32 in. LCD HDTV
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
ILO sound quality
Had a similar issue and turns out I had accidentally switched my language pref to SAP rather than English. As soon as I changed it back, everything was fine...
Aug 10, 2008 | iLO 3200 32 in. LCD Television
Video mode
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
Jan 12, 2008 | Symphonic ST419E TV
RCA F32450 32" TV Logo
24 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
