Question about Vacuums
Numatic Twintec Cable TT4550S Floorcare Machine 776083
Fix the yellow flashing light on a numatic hoover ref hqz 250-2
What is wrong with the yellow flashing light? This is a bag full / low air flow indicator. If your bag is not full then you most likely have a blockage in the hose, wand or tool.
Feb 13, 2015 | Numatic Vacuums
LOUD NOISE NUMATIC NV200 .What can it be?
Hi Elizabeth.It depends how old the machine is and how much work it has done.It could be the motor needs replacing and most good vac repair shops can do this for you.Hope you get it sorted.
You could contact Numatic technical on 01460 68600
Nov 19, 2014 | Numatic Vacuums
How do i bypass pcb board on a henry numatic international"?"
You will need to remove all the wires off it and off the hi/lo rocker switch. Then disconnect to two wires on the opposite side of the on/off to the power in side. The two white motor wires then get connected to this switch. The machine will now run on high speed only when turned on.
Jul 06, 2014 | Numatic Henry Bagged Canister Vacuum
I need a "floor tool" for a Numatic NVQ-380.
Any Janitorial supplier will have them, otherwise contact Numatic (www.numatic.com) who will supply at list price + p+p
Feb 06, 2011 | Numatic NVQ-380 Wet/Dry Vacuum
Numatic Henry Micro HVR-200
motor is over heating. you need to clean bag, filter and hose first then re test
Aug 21, 2008 | Numatic Henry Bagged Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
