Denon 455 hiya robotek i have the same problem as everyone else it seems unit comes on with red led makes a click as transformer gets power but nothing else.I read on the forum that you can help if i have a multi meter which i have.So if you could help me i would be eternaly gratefull as the wife is giving me an earfull to either get it fixed or dump it. Thanks John johncmorgans@ntlworld.com
  • 2 more comments
  • john morgans Jan 25, 2009
    i used to repair televisions for a living so i am fairly good at electronics so any help you could give would be nice
    John
  • john morgans Feb 12, 2009
    thanks for your help but...............
    i get 240volts in but nada out the 12volt relay is switching which is the noise i could hear i seem to have power across the mains switch but nothing going to the board even when i unplug it nothing there i thought it could be a load fault but was wrong.
    as for the suggestions you made i would be happy yo do them if i had any power to the pcb
    Cheers
    John
    just a bit more i am getting 5volts supplied by the front pcb but nothing else so does that prove that the transformers are ok?
    because i am starting to think that 1 of them is open circuit there is a small 1 which supplies 240 volts to the big 1 also supplies on off switch has the 12 relay on same pcb
    john
  • john morgans Feb 22, 2009
    dumped it sorry
  • 1,512 Answers
Hi John
For sure, can at least get an understanding of what may be wrong. You hear the power relay click in, but perhaps no secondary click of the speaker protection relay.  This is generally caused by a fault condition in the amp, resulting in a DC offset voltage being present in the speaker outputs, then detected by the protection circuit, does not allow the speakers to be connected to protect them from damage.  . How far do you want to get into it?
regards robotek
Posted on Jan 25, 2009
  • Graeme Ross
    Graeme Ross Jan 25, 2009
    No worries, And I hope that I can earn that Fixya for my efforts to help you:) Maybe you can pass on to the missus my optimism my optimism that it that it can be fixed, and that YOU are going to do it :)
    .  I take it that the speaker protection relay is not engaging... no momentary pause, then click when you turn the amp on. Can you confirm that with me. If NOT then we would like to check to see which output stage has a DC offset. Pop JUST the lid off, and look for a air cored copper zobel network coil, or a double low value ceramic  5 watt power resistor (may be 2 single resistors connected together) of less than 0.5 ohm. is effectively the speaker output prior to the protection relay for each channel here.  Measure for voltage here before disturbing anything. This is to quickly determine which channel is faulty per the PCB,and confirm that there is a DC offset problem. If you measure anymore than a few millivolts at this point, that is the offending channel.
    Check for burnt resistors about the output stages to also confirm which channel is faulty. Once done, and you are confident that you know which channel is the faulty one, you need to get to the PCB side of the amp by removing the bottom cover and check with strong light and fresh eyes for dry solder joints about the offending output stage. I should also remind that you to work electrically safe.
    Get back to me here with your findings if you like. I will be in and out a bit today (6.00am here now) and we can go from there. Oh and I was serious about working for a FixYa. Any chance of an upgrade:)
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's...
Most likely the unit does not receive power from main transformer. Possible several reasons:
- bad power transformer
- bad main internal fuse 7-8amp. Bad fuse most likely because of one of the channel is blown and shorts the power, so before installing new fuse good idea to check all channels by meter or at least visually for burned parts
- bad power relay
- bad connection, cracked soldering joints
Jul 18, 2011 | Denon AVR-1602 Receiver
Seems to be some sort of power problem since the READY light is no longer on, and therefore the remote control cannot turn the receiver on, nor can pressing the power on button turn it on.
If there is no standby light. Open the top cover and check the fuse on the primary power side. MAKE SURE THE POWER CORD IS UNPLUGGED.There are two transformers in this model. A small one for standby and a large one for the main section.A relay clicks when you touch the power button and switches on the large transformer and the display comes on. If there is any problem in the output stage the the relay will click and the system will go into standby again.
Mar 10, 2011 | Denon AVR-75
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Denon AVR788 has a clicking noise
The clicking noise is the protection circuit that is kicking in and repeatedly shutting off the unit because an internal fault has been detected.
If the problem happened before a power surge, and the power supply looks damaged, then the PSU must be replaced.
If the unit is only 3 months old, better contacting Denon and having the one year factory warranty validated, rather than DIY.
See : Denon USA | WARRANTY or contact Denon for more info on your limitede warranty cover.
If the unit has been taken apart, this may invalidate warranty.
If you want to DIY you can find parts here, or from Denon.
Do not forget to leave feedback.
Thanks.
May 15, 2009 | Televison & Video
Denon AVR-1500 Receiver turns on but only a red blinking light
Hi, I have a Denon arv1500 with a bad tuner. If you can't get yours fixed, would you be interested in selling it--I'd use it for parts.
If you still have it, and would be willing to sell it, let me know! denny@dennyls.com
Mar 22, 2009 | Denon AVR-1500
Stuck in standy
if the amp comes on in standby that means it needs repair
Jan 26, 2009 | Denon DRA-455 Receiver
Denon DRA 455
Hey Skyworth
If you had a meter, I could have talked you through making a few diagnostic tests. Get back to me here with a comment if you want to have a go:)
regards
Graeme
Feb 23, 2008 | Audio Players & Recorders
Denon avr 3000
Anyone want to buy a working Denon AVR-300?
hdurity@comcast.net
Dec 01, 2007 | Denon AVR-2106 Receiver
102 people viewed this question
 Grubhead
Grubhead
