Question about HP TouchSmart IQ504 PC Desktop
IQ504 WON'T BOOT( BIOHD-3) INSTALLED REBUILT HARD DISK AND HAVE RECOVERY DISKS
SOUNDS LIKE IT IS TRYING TO RUN FROM THE CD BUT WON'T
micromend
  • 748 Answers
SOURCE: HP Recovery Disk Error
You said HP told you to do this. I would call them, ask for a supervisor and relate your story. Branding a hard drive takes software not commonly available to customers.
Good Luck
Posted on Mar 21, 2009
support793
  • 81 Answers
SOURCE: Have A HP 735P made recovery disks when computer
The most likely cause of this, is that the new hard drive is not the same as the orginal. Restore media is setup to install only on OEM. Orginal Equipement. If the new hard drive is larger or smaller then the orginal it will not properly load.
The easiest solution to this is if the new hard drive is larger, use a disk setup utility and create a partition the same size as the old drive.
If your drive was retail the software to do this will have been in the box. If you purchased an oem drive you can download the drive setup tools from the manufacturers site.
The drive setup utility is easy to use. Boot to it and choose setup drive. When selected it then procedes to the screen where you will need to set the size of the partition. 1024MB is 1 GB. This will help you detemine the size of the partition you need to set.
Good luck
Posted on Apr 03, 2009
thinktech09
  • 177 Answers
SOURCE: error unitialized corrupt boot structure detected
try repairing the file system using chkdsk with /f switch. However, it is strongly recommended to run this tool only if you have a full data backup
. To do so, click \'Start\' and then \'Run\'. You can then type \'chkdsk /f <drive name>\' in the \'Open\' box and click OK. Here, the drive name should be exactly what is appearing in error message. Alternatively, you can opt for deleting the corrupt partition provided the backup is available. If no good backup exists, you should consider to use a Windows Data Recovery utility. These are powerful and valid Windows partition recovery utilities built to scan the corrupt or deleted partitions and safely recover the lost data. The applications are easy to install and use.
Posted on Jun 11, 2010
riceski
  • 1851 Answers
SOURCE: will not boot up after
From the sounds of it you may have to just reinstall windows. If you do not have the recovery disk you can purchase them from HP for 5.oo USD.
Posted on Dec 27, 2010
  • 30 Answers
SOURCE: HP pavilion a6554f won't boot
it may be a system file error, maybe its corrupted,if you have a recovery disc run it from bios in recovery mode, if you have a windows os copy, run system repair
Posted on May 16, 2011
BIOHD-4/-3 Error
your BIOS is bad, sorry to say... but if the BIOS is glitchy the PC will never run right...tray to talk with an HP Tech...
Jan 13, 2013 | HP Pavilion Computers & Internet
Replaced the MK5065GSX hard drive used the recovery disks but 'no bootable drive' message displayed.
no PC stated
no OS stated
no source of recovery disks stated (HP, MS or crack.org)
or home made?DVD-R or CD-R?
the answer is all you said and more.
lots more.
bad disks wrong disks
bad CD drive
bad HDD drive.
or if laptop then main battery is bad (bigone) and overloads it.
why not boot to live linux disk (optical media)
UBUNTU, 16, FREE, BOOT IT AND HIT TRY ME.
See if PC runs ok.
then if that works run DISKtest during the above demo try me.
if that passes we we are at
bad media install disk you have (no os stated or class of media)
bad cd/dvd drive.
Jan 05, 2018 | HP Computers & Internet
Installed new hard drive p105 s6064 now cd drive wont work dont have recovery discs
Dell recovery will not work in a Toshiba Laptop. Just make sure the boot order is set to CD/DVD driver first that will automatically start the CD/DVD driver when disc is loaded.
Apr 22, 2012 | Toshiba Satellite P105-S6104 Notebook
Emachine E527 won't boot?
From the description your hard drive needs to be replaced, remove hardware and reseat it back in place, sometimes this will restart it. If this fails! have the hard drive tested before replacement.
Apr 16, 2012 | Computers & Internet
Says err1err3 will not boot, does not recognize recovery disks and says biohd 3 no bootable drives
From the information the hard drive has failed, or there might be a motherboard issue, This is where it will need someone to make the determination.
Apr 16, 2012 | HP Pavilion a6750f PC PC Desktop
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
Nov 19, 2011 | Computers & Internet
When a compaq armada m700 laptop is showing non-system disk or disk error replace and strike any key when ready
this usually happens when the computer is trying to boot from a disk that isn't a valid boot disk.
if you have a floppy drive plugged into the multibay and a floppy in the drive, try removing the floppy.
if there is no floppy involved, try to boot from your system recovery disks, as it's likely that the boot record on the hard drive will need repaired. your system recovery disks should walk you through the process.
Nov 03, 2011 | Compaq Armada M700 Notebook
Laptop won't boot. Caps lock and numeric lock lights are blinking. It was working fine after I installed a new hard disk and restored the whole system using my recovery disks and backup. I installed...
Don't restore the system to a hard disk of different size. You may fix the old disk again and use it while using the new (probably larger) disk as an external disk (by fixing a driver bay).
If you want to use the new disk you will have to install the operating system and software from scratch.
Jul 27, 2011 | HP Pavilion dv5-1004nr Notebook
Every time I start my computer it says master boot record error and press a key. After I do it says disk boot failure, insert system disk and press enter. I don't have system disk because my computer...
You can see if there is a recovery partition on you hard drive by pressing the F12 key as soon as you turn on your PC and select boot partition, if not, you will need to buy a set of recovery disks from the manufacturer, it will cost you around $30. If you have a Windows CD you can boot with it and install Windows and download all the device drivers from the manufacturer site. I hope this helps. Good luck and have a fantastic day.
Jun 16, 2011 | Computers & Internet
HP Pavilion Recovery Disks
Sounds like the HDD has failed. Install a new HDD and it should run with the install disks.
May 29, 2017 | Computers & Internet
HP TouchSmart IQ504  PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
