Question about Bruder MAN TGA Container Service Truck
Malfunction engine control unit - Bruder MAN TGA Container Service Truck
Just got a check engine light on P0443.
code p 0443 refers to evaporative emission (EVAP) canister purge valve--circuit malfunction===causes--wiring--EVAP canister purge valve--ECM
code p 0446 refers to EVAP system vent control--circuit malfunction===causes wiring---EVAP purge valve ---ECM
check the wiring and connection to the purge valve unit
Jan 31, 2016 | Cars & Trucks
Trouble code in a 2003 kia Sedona PO106
These are the only ones I have listed
P0100 Mass Air Flow or Volume Air Flow Circuit Malfunction.
P0101 Mass Air Flow or Volume Air Flow Circuit Range/Performance problem.
P0102 Mass Air Flow or Volume Air Flow Circuit Low Input.
P0103 Mass Air Flow or Volume Air Flow Circuit High Input.
P0107 MAP/BARO Circuit Low Input.
P0108 MAP/BARO Circuit High Input.
P0110 A/T Circuit Malfunction.
P0115 Engine Coolant Temperature Circuit Malfunction.
P0116 Engine Coolant Temperature Circuit Range/Performance Condition.
P0117 Engine Coolant Temperature Circuit Low Input.
P0118 Engine Coolant Temperature Circuit High Input.
P0120 Throttle Position Malfunction - Circuit A.
P0122 APP/TPP Sensor Switch Low Input - Circuit A.
P0123 APP/TPP Sensor Switch High Input - Circuit A.
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control.
P0130 Oxygen Sensor Circuit Malfunction - Bankicon1.png 1 Sensor 1.
P0131 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 1.
P0132 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 1.
P0133 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 1.
P0134 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 1.
P0135 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 1.
P0136 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 2.
P0137 Oxygen Sensor Circuit Low Voltage - Bank 1 Sensor 2.
P0138 Oxygen Sensor Circuit High Voltage - Bank 1 Sensor 2.
P0139 Oxygen Sensor Circuit Slow Response - Bank 1 Sensor 2.
P0140 Oxygen Sensor Circuit No Activity detected - Bank 1 Sensor 2.
P0141 Oxygen Sensor Heater Circuit Malfunction - Bank 1 Sensor 2.
P0170 Fuel Trim Malfunction - Bank 1.
P0171 System too Lean - Bank 1.
P0172 System too Rich - Bank 1.
P0261 Injector Circuit Low - Cyl. 1.
P0262 Injector Circuit High - Cyl. 1.
P0264 Injector Circuit Low - Cyl. 2.
P0265 Injector Circuit High - Cyl. 2.
P0267 Injector Circuit Low - Cyl. 3.
P0268 Injector Circuit High - Cyl. 3.
P0270 Injector Circuit Low - Cyl. 4.
P0271 Injector Circuit High - Cyl. 4.
P0300 Multiple/Random Misfire detected.
P0301 Misfire detected - Cyls. 1-4.
P0302 Misfire detected - Cyls. 1-4.
P0303 Misfire detected - Cyls. 1-4.
P0304 Misfire detected - Cyls. 1-4.
P0325 Knock Sensor Circuit Malfunction
P0326 Knock Sensor 1 Circuit Range/Performance - Bank 1 or Single Sensor.
P0335 Crankshaft Position Sensor Malfunction - Circuit A.
P0336 Crankshaft Position Sensor Range/Performance - Circuit A.
P0340 Crankshaft Position Sensor Circuit Malfunction.
P0342 Crankshaft Position Sensor Circuit Low Input.
P0343 Crankshaft Position Sensor Circuit High Input.
P0400 EGR Flow Malfunction.
P0403 EGR Circuit Malfunction.
P0404 EGR Circuit Range/Performance Malfunction.
P0420 Catalyst System Efficiencyicon1.png below Threshold - Bank 1.
P0422 Main Catalyst Efficiency below Threshold - Bank 1.
P0440 Evaporative Control Malfunction.
P0441 Evaporative Control System - Improper Purge.
P0442 Evaporative Control System - Small Leak detected.
P0443 Evaporative Control System Purge Control Valve Circuit Malfunction.
P0446 Evaporative Vent Control Circuit Malfunction.
P0447 Evaporative Vent Control Circuit Open.
P0448 Evaporative Vent Control Circuit Short.
P0450 Evaporative System Pressure Sensor Circuit Malfunction.
P0452 Evaporative Control System Pressure Sensor Low Input.
P0453 Evaporative Control System Pressure Sensor High Input.
P0455 Evaporative Control System - Large Leak detected.
P0470 Exhaust Pressure Sensor Malfunction.
P0500 Vehicle Speed Sensor Malfunction.
P0501 Vehicle Speed Sensor Range/Performance.
P0505 Idle Air Control System Malfunction.
P0506 Idle Air Control System Malfunction - RPM Lower than expected.
P0507 Idle Air Control System Malfunction - RPM Higher than expected.
P0510 CTP Switch Malfunction.
P0561 System Voltage Unstable.
P0562 System Voltage Low.
P0563 System Voltage High.
P0601 Internal Control Module Memory Checksum Error.
P0604 Internal Control Module RAM Error.
P0703 Torque Converter/Brake Pedal Switch Malfunction - Circuit B.
P0705 Transaxle Range Sensor Circuit Malfunction (PRNDL Input).
P0706 A/T Range Sensor Circuit Range/ Performanceicon1.png.
P0710 Transaxle Fluid Temperature Sensor Circuit Malfunction.
P0711 A/T Fluid Temperature Sensor Circuit Range/Performance.
P0715 Input/Turbine Speed Sensor Circuit Malfunction.
P0722 Output Speed Sensor Circuit No Signal.
P0726 Engine Speed Input Circuit Range/ Performance.
P0727 Engine Speed Input Circuit - No Signal.
P0731 A/T Gear 1 Improper Ratio.
P0732 A/T Gear 2 Improper Ratio.
P0733 A/T Gear 3 Improper Ratio.
P0734 A/T Gear 4 Improper Ratio.
P0740 Torque Converter Clutch System Malfunction.
P0743 Torque Converter Clutch Circuit Electrical.
P0750 Shift Solenoid "A" Malfunction.
P0753 Shift Solenoid "A" Electrical.
P0755 Shift Solenoid "B" Malfunction.
P0758 Shift Solenoid "B" Electrical.
P0760 Shift Solenoid "C" Malfunction.
P1000 Readiness Function Code.
P1115 Engine Coolant Temperature Signal from ECM to TCM.
P1121 Throttle Position Sensor Signal Malfunction from ECM to TCM.
P1170 Front Heated Oxygen Sensor Stuck.
P1195 EGR Pressure Sensor (1.6L) or Boost Sensor (1.8L) Open or Short.
P1196 Ignition Switch "Start" Open or Short (1.6L).
P1250 Pressure Regulator Control Solenoid Valve Open or Short.
P1252 Pressure Regulator Control Solenoid Valve No. 2 Circuit Malfunction.
P1307 Chassisicon1.png Acceleration Sensor Signal Malfunction.
P1308 Chassis Acceleration Sensor Signal Low.
P1309 Chassis Acceleration Sensor Signal High.
P1345 No SGC Signal (1.6L).
P1386 Knock Sensor Control Zero Test.
P1402 EGR Valve Position Sensor Open or Short.
P1449 Canister Drain Cut Valve Open or Short (1.8L).
P1450 Excessive Vacuum Leak.
P1455 Fuel Tank Sending Unit Open or Short (1.8L).
P1457 Purge Solenoid Valve Low System Malfunction.
P1458 A/C Compressor Control Signal Malfunction.
P1485 EGR Solenoid Valve Vacuum Open or Short.
P1486 EGR Solenoid Valve Vent Open or Short.
P1487 EGR Boost Sensor Solenoid Valve Open or Short.
P1496 EGR Stepper Motoricon1.png Malfunction - Circuit 1 (1.8L).
P1497 EGR Stepper Motor Malfunction - Circuit 2 (1.8L).
P1498 EGR Stepper Motor Malfunction - Circuit 3 (1.8L).
P1499 EGR Stepper Motor Malfunction - Circuit 4 (1.8L).
P1500 No Vehicle Speed Signal to TCM.
P1505 Idle Air Control Valve Opening Coil Voltage Low.
P1506 Idle Air Control Valve Opening Coil Voltage High.
P1507 Idle Air Control Valve Closing Coil Voltage Low.
P1508 Idle Air Control Valve Closing Coil Voltage High.
P1523 VICS Solenoid Valve.
P1586 A/T-M/T Codification.
P1608 PCM Malfunction.
P1611 MIL Request Circuit Voltage Low.
P1614 MIL Request Circuit Voltage High.
P1624 MIL Request Signal from TCM to ECM.
P1631 Alternator "T" Open or No Power Output (1.8L).
P1632 Battery Voltage Detection Circuit for Alternator Regulator (1.8L).
P1633 Battery Overcharge.
P1634 Alternator "B" Open (1.8L).
P1693 MIL Circuit Malfunction.
P1743 Torque Converter Clutch Solenoid Valve Open or Short.
P1794 Battery or Circuit Failure.
P1795 4WD Switch Signal Malfunction.
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short
Oct 01, 2014 | Vehicle Parts & Accessories
What is p1215, found in Rav4 new model 2002?
p1215 code may be as malfunctioning ECM (engine control module). The ECM is also commonly referred to as the computer or ECU (engine control unit).are you experiencing harsh shifts of the transmission, hesitation between shifts, intermittent Check engine light?
May 07, 2014 | 2004 Toyota RAV4
I have an 04 Kia spectra with a PO121 code. What domestic this mean
Well.... Here is a full list of the codes I can find that Kia list. Oddly it jumps from P0120 to P0122
I hope the attached will help, but you may need to talk to your dealer.
Diagnostic Codes
Kia
Without Onboard Diagnostics (OBD-II)
2 Distributor no Signal.
3 Distributor G Signal.
7 Fault on SGT Signal.
8 Mass Air Flow Sensor.
9 Engine Coolant Temperature Sensor.
10 Intake Air Temperature Sensor.
12 Throttle Position Sensor.
14 Atmospheric Pressure Sensor.
15 Oxygen Sensor.
16 EGR Valve Position Sensor.
17 Feedback System.
18 Injector No. 1 open or short.
19 Injector No. 2 open or short.
20 Injector No. 3 open or short.
21 Injector No. 4 open or short.
24 Fuel Pump Relay open or short.
25 Pressure Regulator Control Solenoid Valve.
26 Purge Control Solenoid Valve.
28 Solenoid Valve (EGR) open or short.
34 Idle Speed Control Solenoid Valve.
35 Deteriorated Injector.
36 Deteriorated Air Flow Sensor.
37 Intake System Air Leakage.
41 Variable Inertia Charging System Solenoid Valve.
46 A/C Cut Relay open or short.
48 Power Stage Group 1 Malfunction (inside ECM). Injector 1-4 Purge Solenoid Valve, EGR Solenoid Valve or Damaged Power Stage.
49 Power Stage Group 2 Malfunction (inside ECM). Idle Speed Control Valve Failure or Damaged Power Stage.
56 Idle Speed Control Valve Closing Coil open or short.
57 A/C Compressor Input Signal short.
73 Vehicle Speed Sensor open or short.
87 Malfunction Indicator Lamp short Circuit.
88 ECM Data.
99 Battery.
OBD-II
P0130 Oxygen Sensor Circuit Malfunction - Bank 1 Sensor 1.
P0420 Catalyst System Efficiency below Threshold - Bank 1.
P0706 A/T Range Sensor Circuit Range/ Performance.
P1307 Chassis Acceleration Sensor Signal Malfunction.
P1496 EGR Stepper Motor Malfunction - Circuit 1 (1.8L).
P1797 P or N Range Signal or Clutch Pedal Position Switch Open or Short.
Jun 21, 2011 | 2004 Kia Spectra
Malfunction indicator lamp in my toyota corolla is on how i fix?
The check engine light also called the malfunction indicator comes only when the computer control unit (called the PCM) senses a fault in the electronic controls of the engine and/or the emission system, there are about 200 possible faults that turn the light on, to know what has developed a problem you must have the system tested, this is called an OBD2 fault code test, Kragen and Autozone parts stores do this testing for free.
May 27, 2010 | 2002 Toyota Camry
How do i check my codes in a 86 nissan z24 pickup
The self-diagnostic system identifies malfunctions of signal systems such as sensors, actuators and wire harnesses based on the input signals received by the ECCS control unit. Various malfunctions are coded and displayed on the control unit by a series of blinking red and green lights. Results of the self-diagnosis are retained in the control unit's memory and are displayed when the mode selector, located on the rear of the control unit, Fig. 122, is switched to the On position. When displaying malfunction codes, the code number can be determined by counting the number of light pulses. The red light represents the first digit of the code, while the green light represents the second digit of the code. For example, a Code 32, would be displayed as three flashes of the red light, followed by two flashes of the green light. Malfunction codes can be translated as follows:
  1. Code 11 -- Crank angle sensor circuit malfunction.
  2. Code 12 -- Air flow meter malfunction.
  3. Code 13 -- Water temperature sensor circuit malfunction.
  4. Code 21 -- Ignition signal malfunction.
  5. Code 23 -- Idle switch circuit malfunction.
  6. Code 24 -- Transmission switch and clutch switch circuit malfunction.
  7. Code 32 -- Starter signal malfunction.
  8. Code 42 -- Throttle sensor circuit malfunction.
  9. Code 43 -- Injector circuit malfunction.
  10. Code 44 -- All monitored systems satisfactory.
May 10, 2010 | 1986 Nissan Pickup 4WD 1986
Engine stalls. 4 times engine stalls, let sit for
sounds to me that there could be an engine temperature switch that is malfunctioning or not working at all. the temperature switch tells the engine that its cold and that the fuel injection system should operate in cold mode. the switch then tells the computer to start the engine in cold mode. if it malfunctions, the engine controlling unit confuses itself and then cuts off. this is an early sign of that unit failing until the car won't start at all. it's just wear and tear and time that does these things. a good mechanic should help you out quick and should be a couple of ours work. good luck
May 07, 2010 | 1992 Lexus Ls 400
Aculaser 8500 error e525
EPSON AcuLaser C8500 Revision D
Troubleshooting Overview 5-19
1.1.4.4 Service-Call Error Messages
See the following tables for the detailed information on the Service-Call
Error messages.
Engine Related Service-Call Error
*1: Does not appear with this printer because the printer’s life ends earlier.
Table 1-2. Engine Related Service-Call Errors
Error Type
E
Error Code
fff Explanation FIP
E 113 Fuser Unit malfunction (No Fuser Unit) FIP-1.2
E 510 ROS motor malfunction FIP-1.16
E 511 Motor 1 malfunction FIP-1.15
E 512 P/H Motor malfunction FIP-1.14
E 513 NVRAM malfunction FIP-1.13
E 516 Duplex Unit malfunction (Communication) *
E 517 Optional single/double c*ssette malfunction *
E 520 2nd BTR malfunction (Advance) FIP-1.24
E 521 2nd BTR malfunction FIP-1.23
E 523 PCDC malfunction FIP-1.21
E 524 Toner density malfunction (Low density) FIP-1.20
E 525 Toner density malfunction (High density) FIP-1.19
E 526 ADC sensor soiled FIP-1.18
E 527 Deve home position sensor malfunction -
E 530 Environment (humidity)sensor malfunction FIP-1.27
E 531 PR Motor malfunction FIP-1.15
E 532 P/H Motor2 malfunction FIP-1.14
E 533 Thermosensor malfunction FIP-1.25
E 534 Fuser Unit malfunction (Low Temperature) FIP-1.26
E 535 Fuser Unit malfunction (Lamp) FIP-1.26
E 536 Fuser Unit malfunction (Time out) -
E 537 Fuser Unit malfunction (Overheat) FIP-1.25
E 543 Rear fan malfunction FIP-1.30
E 544 Fuser Unit fan2 malfunction -
E 545 Fuser Unit fan1 malfunction FIP-1.28
E 546 Duplex Unit motor malfunction *
E 547 Optional single/double c*ssette unit feeder
motor malfunction *
E 620 K Deve service life FIP-1.31
E 621 C Deve service life FIP-1.31
E 622 M Deve service life FIP-1.31
E 623 Y Deve service life FIP-1.31
E 624 IBT service life FIP-1.31
E 626 2nd BTR service life FIP-1.31
E 627 IBT cleaner service life FIP-1.31
E 830 Optional double c*ssette unit LC3
malfunction *
E 831 Optional single/double c*ssette unit LC2
malfunction *
E 832 MP tray malfunction (lift down) FIP-1.40
E 833 MP tray malfunction (lift up) FIP-1.39
E 998 Engine communication error FIP-1.43
Error Type
E
Error Code
fff Explanation FIP
conclusion :
check the toner if its well plugged. or correctly.
of its leaking or etc.
Feb 19, 2010 | Epson AcuLaser C8500 Printer
2001 dodge truck wont start
dear friend:code p1601 stands for engine control module(ecm)transmission control unit(tcm)-serial peripheral comminication malfunction,code p1282 stands for fuel pump relay-open circuit,fuelpump relay faulty and p1687 stands for metering oil pump-high flow-circuit malfunction,(wiring metering oil pump switch metering oil pump and ecm
Sep 22, 2009 | Cars & Trucks
Bruder MAN TGA  Container Service Truck Logo
796 people viewed this question
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
