Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Would like to connect to my existing belkin54g wireless router
Bought new pc, would like to connect to existing belkin54g router, asking for security key or passphrase. could you help.
  • Anonymous Feb 05, 2009
    bought new pc, would like to connect to existing belkin54g router, asking for security key or passphrase. could you help.
  • 77 Answers
Do you have the "default" ones? you may need to reset the router
Posted on Feb 04, 2009
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    May 15, 2012 | Encore Enhwi-2an3 Wireless-n Router
    I have comcast Cable tv and internet with a belkin54g wireless router can I add another wireless router faster and just for me?
    yes, run a cat 5 cable from your existing router to the input (WAN or LAN) port of your new router, set the unit up with a pass word that only you know, now you will have a VPN (virtual private network)
    Mar 11, 2011 | Belkin Computers & Internet
    I'm trying to connect my new ipad to my wi-fi and cannot remember my password for my Belkin54g router. I have entered every possible combination of the barcode numbers, usual passwords and anything else I...
    WIRELESS SECURITY ISSUES
    Step 1 : Connect Router - Computer ( Wired)
    Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
    Step 3 : On the Left under wireless Click Security
    Step 4 : If it asking for a password leave that blank and click submit
    Step 5 : On this Page you can find the WPA Key ( If it is a bunch of dots then Uncheck "OBSCURE PSK ")
    Step 6 : IF the security mode is WEP then the key 1 will be your password
    Regards
    TOM
    Dec 26, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
    I have a belkin54g router that has this error message on it. Ive gone to the 192.168.2.1 browser and set up a 64bitWEP. i want to set up a password to connect to my router for security
    Is there any computer connected to the router ?
    If not then you will need to connect the computer to the router.
    Do not change any wireless settings on the router with the wireless computer.
    you will need to connect the computer to the router with the Ethernet cable.
    check the IP address of the computer.
    open the router set up page of the router.
    Here you can change the wireless settings of the router.
    Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
    Click Here for step by step instructions
    May 19, 2010 | Computers & Internet
    Security key invalid for new PC with windows 7 OS to connect to my existing router
    Hi. I think you should contact your Internet Service Provider for the security or just ask them on what is the security key. Also you could ask if you want just disable the password so that you can just connect to your wireless router without the password or just ask them to configure your router to have your prefer password. Hope this helps
    Apr 14, 2010 | Computers & Internet
    I need the security key to my existing wireless netgear router.
    The Security Key is normally used for Wireless routers to protect your connection from any unauthorized use. As you have said that you do not have the Security key for your router with you, the best way to connect your ACER laptop to the Netgear router is by asking your Wireless service provider to reset the security key & freshly reentering the same on both of your HP & ACER laptops.
    Feb 06, 2010 | NetGear RP614 Router
    Have belkin54g wireless router. Now wont connect
    Right under screen there should be a button, or the f8 key I think is another one. You can also search you computer for Wireless Assistant which will turn it on for you.
    Jan 27, 2010 | Computers & Internet
    How can I secure my Belkin54g?
    go to router configuration page in that wirless is there option in that seciurty option is there then give the wep or wpa option then give the password then save it re-try it to connect
    Mar 09, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
    Been given a i pod touch for christmas ....on it its asking for my chosen network which is belkin54g i touch screen asking for a password ..... i dont have a password for the belkin54g please help thanks
    check your router and make sure there is no password in the security tab. You may need to use a wep or wap pass phrase a password to connect.
    Dec 30, 2008 | Computers & Internet
    Input of incorrect WEP settings on notebook
    There are 2 things you can do. One is to connect the router to the notebook via ethernet cable. You will then be able to enter the router's page by typing 192.168.2.1. The other option is to reset the router to its default factory settings. This is done by pressing the reset button on the back of the router and hold it down for 30 seconds with power still on.
    May 10, 2008 | Belkin (F5D5231-4) Router
    Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
    161 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
