Question about Nokia Classic 2700 Cell Phone
Nokia 270c discharge battery solution - Nokia Classic 2700 Cell Phone
How to fix nokia 103 battery discharge
You can't fix a Battery's over discharge problem, it's faulty. Change to a new one, or contact Nokia Care, if they can cure it.
Apr 26, 2014 | Nokia Cell Phones
I'm using nokia 7210s my battery are 8hr only
You can discharge the battery to 10% and then full charge it, take this circle for several times. If it can not help, maybe it is the problem of your new battery.
Further more, you can check if some app is running
Jul 28, 2013 | Cell Phones
NOKIA 5233 BATTERY HEAT UP AND FAST DISCHARGE ON STANDBY
you can replace new battery for the moment and charging again. so if your mobile getting heat again may be short circuit on your mobile phone
Feb 03, 2012 | Nokia 5233 Cell Phone
Want to erase contents of my motorola 270c
Some of the options in the mobile itself.........
Sep 29, 2011 | Motorola Mobility 270C Cellular Phone
My nokia 6300 phone become heat during charging.and battary is also discharge rapidly
Hi
not heat but warm battery during charging is normal...but if discharges rapidly your battery may have reached the end of life..before buying a new battery pls make sure that your charger is ok...you can test it with another nokia with same charging plug..all the same on Nokia..
Hope this helps!
Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 21, 2011 | Nokia 6300 Cell Phone
I havnt used nokia 6300 for 3 months , how to recharge battery
Because it has fully discharged, the battery has to be replaced. Try replacing the battery.
Rate this.
Apr 29, 2009 | Nokia 6300 Cellular Phone
Battery gets discharged
Possible Problems:
1. Maybe there's a virus.
2. Often restart can drain the battery.
Possible Solution:
Format it by pressing the green key or call key + no. 3 + asterisk(*) at the same time. But 1stly, turn off ur fone, then b4 the NOKIA logo appears, hold these following keys altogether. You will see the "Formatting" word afterwards..
OR...
Format it by typing *#7370.
Aug 03, 2008 | Nokia 3230 Cellular Phone
Nokia 8800 discharging prob
Nokia 8800 has the worst battery ever. Its a known issue. You need to have your phone flashed at a nokia service center, and get the new 8800 battery which ships on the 8800 sirocco BL6X.
Jan 24, 2008 | Nokia 8800 Cellular Phone
Nokia Classic 2700 Cell Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
