Question about Velbon Sherpa 555rii 555 R Ii Camera Photo Tripod With Ballhead Qhd-53d & Qb-62
How to attach velbon super mag slider to Velbon sherpa 555R
I want to buy the velbon super mag slider, but I'm not sure you can attach it to the Velbon sherpa 555R.
SOURCE: Missing part on Tripod - Velbon Victory 550
Where can I get parts?
I got from friend a Velbon Victory 550 tripod. The handle that prevent the head from tilting is missing, and so is a piece of plastic that apparently held the rod upon which the head of the tripod is placed from shaking.
thank you
Posted on Feb 03, 2008
SOURCE: Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
Posted on Apr 16, 2008
Midwest-tech
  • 243 Answers
SOURCE: Velbon VGB-3C
i have had this happen before many times. You can just pick up another bolt and fastener from your local hardware store that will fit in place of the original. It takes a little bit to find the right ones but they had the right ones.
hope this helps.
thanks,
Nate
Posted on Aug 22, 2008
SOURCE: parts for a velbon tripod
hi there, i think you can obtain the parts directly from Hakuba USA. www.hakubausa.com they're the USA distributers for Velbon and will actually repair it... if you can't by simply replacing a part. also a phone # 1-800-423-1623 and a seperate # 800-886-2236 to order quick release plates.
Posted on Jan 05, 2009
SOURCE: How to remove pan head from velbon 530, it feels
I have the Hakuba HG-503MX which came with basically the same pan head you have already attached to the center column. First remove the center column from the tripod, with the pan head attached. Tighten the knob that prevents the pan head unit from rotating 360 degrees on the center column and gripping the head with one a hand and the center column near the plastic plate firmly twisting the head counter clockwise. The pan head will unscrew from the plastic plate which sits on top of the center column, given enough force. My pan head was also very tightly screwed onto the shaft, since it came already attached to the tripod. Hope this is helpful.
Posted on Oct 17, 2009
Need to replace the slide which attaches the three leg braces on a Velbon Videomate 607.
If you're in the UK or Ireland, contact Velbon here. For the rest of the world, contact them here.
Apr 19, 2012 | Velbon VIDEOMATE 607 Tripod
What do I need to attach a Castel-XL focusing rack to my DV 7000 tripod? The attachment piece with the tripod does not attach in a sturdy fashion.
The XL attahes with a 1/4 or 3/8" camera screw or via an Arca compatible QR. If it is not tight on your tripod the problem is probably in the tripod head.
Jul 19, 2011 | Velbon Sherpa DV7000 Tripod
DV7000 tripod locking screws for legs and for central, extending column are missing, where can I get replacements
Hi, Folks!
I just cracked the Velbon's DV-700 tripod head mounting screw, that is on the top of the extending column. I need a replacement for this. Screw is on the top of the column.
Any suggestions?
Thank's in advance
Sep 24, 2010 | Velbon Sherpa DV7000 Tripod
Im missing the plate/adaptor w/1/4 20 threads
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Aug 03, 2010 | Velbon Sherpa DV7000 Tripod
Fluid in velebon tripod
I cannot tell you esactly, but it seems to be more of an oil or grease than a liquid.
May 15, 2010 | Velbon Sherpa DV7000 Tripod
Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
Canon 400D with EF 100-400 Zoom lens
I wouldnt chance it but get a good heavy one with metal locks and such
Dec 26, 2007 | Velbon Sherpa DV7000 Tripod
Broken paning head
That sticky stuff should be grease for the roller bearing that rolled away on you. Dont chance it Purchase a new one for you cameras sake
Sep 18, 2007 | Velbon Sherpa DV7000 Tripod
Broken Velbon Tripob
Contact them for parts. Email would be the easiest way.
VELBON CORPORATION
ADDRESS
6-1-5 Nogata Nakanoku
Tokyo 165-0027 JAPAN
Telephone: +81- (03) 5327-6105
Fax: +813 5327 6117
E-mail: support@velbon.com
Apr 25, 2007 | Velbon ELCARMA540 Tripod
Velbon Sherpa 555rii 555 R Ii Camera Photo Tripod With Ballhead Qhd-53d & Qb-62 Logo
37 people viewed this question
Top Velbon Photography Experts
JP Services
JP Services
Bill Eager
Are you a Velbon Photography Expert? Answer questions, earn points and help others
