Question about Nakamichi PA-504 Car Audio Amplifier
Channel 2 volume is very low
I had my PA-504 hooked up to 4 speakers, one on each channel. One day a passenger told me the speaker next to her wasn't working. I tested it later and found that it was working ... but at a very low volume. When channel 1, 3 and 4 are at normal volume, channel 2 is barely audible. I have checked and re-checked all connections and they all were in order. Does anyone know what this could be? Did I blow channel 2 (even though I NEVER turn it up too loud), and is it fixable? Thanks.
  • Tommy Walker Jul 13, 2007
    Yes, I already tried switching all the RCAs, I guess it's blown ... sucks to be me! I wonder how much a repair like this is gonna cost me!
    Scholar:
  • 36 Answers
You can check if channel 2 is blown by switching around your RCA plugs. If you are using the speaker wires as high power inputs you can change them. I.E. swap the left channel with the right one. I assume you checked the gain control on the amp. If channel 2 works with channel 3's inputs then its your head unit or the wiring. If you are lazy take the amp to a car audio store and ask them to bench test it for you. Hack
Posted on Jul 13, 2007
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
Hooked to surround sound, two front speakers, 4 wall speakers, 1 sub woofer. Restart unit and reduce volume unit is OK but normal talking is too low.
Voice tracks are usually routed to the center channel. You don't mention having a center channel speaker hooked up. If this is the case, then you need to go into the receivers setup menu and set it for no center. This will reroute the voice tracks to your front speakers.
Feb 24, 2016 | Onkyo TX-DS575 Receiver
Why does the Uniden 40-Channel CB Radio (PRO505XL) "PA" acts like an extra external speaker!
nothing,thats what its supposed to do. Don't try transmitting on pa though you will blow that speaker. the type you would need is a bull horn speaker.
Jul 07, 2014 | Uniden Pro505xl 40 Channel Cb Radio
I have a mtx audio thunder 4202 amp is it just meant to use for sub woofer or can it be used for front speakers as well ? is it 2 or 4 channel and what does that men?
yes, the amp can be used fof full range speakers. to use it a s such, the amp's "crossover" switch must be set to "off" (could also be labeled as "full-range" or "defeat").
the amp is 2 channel. 4 channel is for surround sound or to have independent front and rear channels/volumes. this 2 channel amp will support 4 speakers, but you wont be able to balance from front to back- the front and back speakers will be at the same volume all the time if both are hooked up to the amp.
Mar 12, 2011 | MTX Car Audio & Video
I hooked up my xd1225 cd player in my car and it gets SUPER hot/overheats. What did I do wrong?
your speakers are of an incorrect ohmage, or you have too many speakers hooked up to it. your stereo likely calls fo a singler 4 ohm (4?) speaker per channel and the factory speakers may be lower than 4 ohms, or you have several speakers hooked up to the same channel. there should be 4 channels, each with no less than a 4 ohm (4? ) load. two 4 ohm speakers wired to the same channel in parallel (both attached to the amp's poositive/negative leads) will create a 2 ohm (2?) load, and overheat the amp. if the 2 speakers are a woofer/tweeter combination, and there is a capacitor involved, it may be ok, but 2 woofers, or a woofer and a subwoofer hooked to the same channel will likely reduce the ohmage below 4 ohms (4?). look at the back of each woofer speaker, and look for an ohmage rating stamped to the back of the speaker magnet to verify that they are 4 ohm (4?) speakers, and verify that only a single 4 ohm speaker is hooked to each channel. the car likely has multiple speakers hooled up to each channel, which would lower the ohmage rating below 4 ohms (4?).
Mar 09, 2011 | Dual Electronics XD1222 Car USB Player
I have a 1200watt amp that's only providing 300watt output with 8ohm Behringer B212 speakers. Is there a resolution and what would it be?
I'd need to know more about the amp, but don't forget, amps are rated as their max power...
So lets take a 300W/channel stereo amp at 8 ohms.
Ok, it's stereo, so there's 600W
But the amp is capable of 4 ohm loads...well, now you can deliver 600W/channel, for a total of 1200W
In this scenario, your amp is doing exactly what it was designed to do with those speakers.
If you wanted to get the full 1200W out of the amp, you'd have to hook up 2 more speakers in parallel to the ones already there. This drops the impedance to 4 ohms per channel = 600W / channel.
Yes, the power is split among the apeakers...300W per speaker into 4 speakers = 1200W
so any way you look at it, there's your 1200W
Feb 27, 2011 | Behringer B212 600watt, 2-Way PA Speaker
Can I hook up 4 speakers to my RCA system?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/RCA-RS2653-manual/id/404ci767/t/2/
Do you mean other than the ones that came with it? NOT recommended. But not impossible either. You assume all risk of equipment damage if you proceed.
First, kiss your warranty goodbye.
I'd go with a series connection or you WILL present too low an impedance to the modest amps.
That means + to minus on one speaker, then + of that speaker to - of the next, then + of that speaker back to - on the amp. Repeat for the other channel.
Start with LOW VOLUME and see how the amp reacts. Of course, you'll have no way of controlling individual volumes so if the speakers are mistmatched it won
Feb 26, 2011 | RCA 100-Watt Stereo System With 5-CD...
Peavey PV 8.5C DDT is activated on channel A even al low volume, channel B works fine. All 8 power transistors on both channels were found OK. Driver transistors and 15V zener diodes are all OK as well....
Check your speakers and Cables. I had some speakers that traveled in my small trailer and the vibrations of the trailer caused the diaphram to back off my horns. Once I got the speakers fixed the DDT light on my power amp stopped staying on so much.
Jan 07, 2010 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
SOLID AUDIO F-45 4CH 900W ONE OF THE FRONT CHANNELS ...
HI DUDE TRY TO CONNECT ONLY 2 PC OF UR 6x9 AT FRONT CHANNEL TRY IT OUT COZ IT MAYBE THE DONT HAVE MUCH POWER TO HIT VOLUME OR ELSE TAKE OUT UR SUB CONNECT TO FRONT CHANNEL OR CHECK UR SUB VOLUME .,...
Apr 01, 2009 | Solid Audio Formula Series F45 4-Channel...
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Nakamichi PA-504 Car Audio Amplifier Logo
187 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Mohamed Ismail
Mohamed Ismail
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
