Question about Bush Televison & Video
Put dvd in combi tv/DVD wrong way round and won' t eject
hardrocko
  • 1476 Answers
SOURCE: dvd won,t eject
This is going to require opening the unit and taking the DVD unit covers off. If you feel confident and are good with tools and have a good memory (to remember how it all goes back together), you should be able to get the DVDs out. Just remember to be careful inside the unit, go slow and don't force anything. After the DVDs are out and you have the unit back together properly it should be OK if no damage was done to the laser assembly. Good luck.
Posted on Jun 26, 2006
siphilips
  • 34 Answers
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Posted on Nov 05, 2007
SOURCE: BUSH TV/DVD combi
connection between tv and dvd might be wrong or need to be checked
Posted on Dec 03, 2007
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Posted on Jul 17, 2008
  • 3 Answers
SOURCE: Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Posted on Jul 07, 2009
Blaupunkt tv dvd combi saying wrong region
NTSC/PAL/SECAM Color System
Europe used PAL/SECAM format, check settings on tv
Dec 06, 2013 | Bush Televison & Video
DVD won't eject and tv turns off when it tries
if it doesnt eject,it might mean that its broken and might want to have an expert take a look at it.
Jul 24, 2013 | Televison & Video
Recently bought a toshiba tv and dvd combi but wont play any dvds
You need to go in the menu and change the region code. yours is not set for amarican made dvd's
Mar 05, 2013 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
My Technika TV/DVD Combi was playing a DVD but then made a noise like it was trying to skip tracks before going off. When I try to go back on to the DVD it says "no signal" and won't...
Hi.We can't help you here. Take it to a repairman. Inside you maybe able to check for a fuse but nothing else. If the cost is more than a new TV than you can decide for yourself. Good luck
Jun 28, 2011 | Televison & Video
I put in a dvd, it starts to read it, and in a couple of seconds it ejects
Hello; There are many laws and rules controlling what you can watch on all DVD players, built into a TV or separate player. If you go buy an MGM or other dvd of some movie at Walmart , Best Buy ETC it should play in your DVD player, But if You or somebody " Burned a DVD" , It Likely won't play. If The DVD is an original store copy and still won't play, the DVD chassis must be replaced. BIG BUCKS. Just buy a Cheap DVD player and plug into the jacks on the back of the TV and save a TON of money. John
Jun 27, 2011 | Emerson LD195EM8 19 in. LCD TV
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
May 21, 2011 | Toshiba 14DLV75 14 in. TV/DVD Combo
My daughter put a vhs in her vcr/dvd combi. Now the vhs is chewed and stuck so it won't come out and the tv and dvd player automatically shut off
Take dvd/vcr combo aparts.Turn on the power to the machine,one hand move around the inter eject vcr port for those sensors,the other hand just keep pushing the eject button,keep doing this until the tape eject and come out.
Jun 14, 2010 | Televison & Video
Bush tv/dvd combi
your daughter has done nothing wrong, certain dvd,s have region codes for different countries.you can program the player with your remote, but you will need the hack number.i,m looking for it myself, so if you find it,pass it on!
Oct 17, 2008 | Televison & Video
Televison & Video Logo
111 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
