Question about Liebherr Custom Finish 24" Right Hinge Built-In BioFresh/Refrigerator - RBI-1400
Liebherr 3866 index 20/147, freezer stops, alarm sounds, we then unplug for a short while and replug then all is well untill after another few hours, fridge is fine.
4 Suggested Answers
SOURCE: I have a Liebherr fridge freezer. Model n0 CNES
I left the fridge closed for 12 hours after cleaning and the back wall is now frost free.Great!! Lynn
Posted on Sep 09, 2009
  • 93 Answers
SOURCE: alarm won't stop beeping
Door left open or temp is too warm. most I found is heavy ice build up on freezer evaporator, very easy to tell, pull out one of the drawer and look on the back wall, it should not have any ice on it (a little frost is OK). It may be bad Evaporator sensor, Evaporator fan motor is not running, door evaporator fan reed switch installed upside down,bad connection on defrost heater connector, bad defrost heater element, open heater HI limit switch, open gap on door gasket and compressor never stop running. If no ice build up and compressor is running but temp is rising then it may be sealed system problem. Good Luck.
Posted on Mar 01, 2010
Liebherr refrigerator freezer model # cs 1601 79-362-3844 index 101/237 had an inch thick of ice on the bottom. I turned it off using the on/off switch for the freezer and left the refrigerator on.
Is the fan running inside the freezer? To see that you have to remove the back panel of the freezer. Also how much stuff are you putting into the freezer please make sure you are not blocking the vents inside the freezer. Also when you remove that back panel ensure the vent tubes to the fridge area are not blocked.
Jul 06, 2017 | Refrigerators
Why is it beeping sporadically?
It looks like it needs service of some sort. Have you referred to its manual?
May 13, 2015 | Liebherr CS1601 (15.5 cu. ft.) Bottom...
The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
Oct 18, 2012 | Liebherr Refrigerators
How to stop alarm of freezer
Unplug it for about 10 minutes to allow any capacitors to dissipate. Switch back on. If alarm starts straight away, suspect faulty controller, probably caused by the spike in the power supply
Apr 18, 2012 | Freezers
Liebherr frige/freezer switching on/off by itself
its the main board relays on the board on the back panel or just inside the lower area on the left wall near the compressor compartment
Jul 30, 2010 | Refrigerators
Making alarming buzzing sound. Still freezing fine
putting unfrozen food in a freezer can raise the temp to cause it to go off allow 24 hours for it to stop if it dont replace the buzzer
May 23, 2010 | Whirlpool Upright Freezer EV161NZRQ
FREEZER ALARM WILL NOT SHUT OFF
You can try 2 things. Unplug it for about 2-3 minutes and then replug it. It should reset itself. You can silence the alarm or muffle it. Silencing it should be hard. Disconnect it from its source. You may want to find out why it is alarming constantly. Have you called Sears and asked them?
Feb 09, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Apr 28, 2008 | Refrigerators
Liebherr Custom Finish 24" Right Hinge Built-In BioFresh/Refrigerator - RBI-1400 Logo
20 people viewed this question
Top Liebherr Refrigerators Experts
Dan Webster
Dan Webster
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
