Question about Asrock P4 COMBO P4/S478+LGA775/848P/DDR400/SATA/A&L/ATX Motherboard (MOTASR28)
Amptron g31lm lga775 - Asrock P4 COMBO P4/S478+LGA775/848P/DDR400/SATA/A&L/ATX Motherboard (MOTASR28)
I've lost the manual for my Amptron motherboard K7-810DLM2K. Amptron motherboard with an AMD D2000 (Duron 1.3 GHz).
Hello the manual should be available here:
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=203&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
You will maybe need adobe reader to read content
Or select another model by selecting:
Mainboard.
Socket 462
The model number
And Version number of mainboard.
Or install this program for more detailed info:
http://www.piriform.com/speccy/download
Good luck
Feb 22, 2011 | Amptron PM-9100A Motherboard
Driver for amptron i945lm4 version 1.4
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Jul 08, 2010 | Amptron PM-9100A Motherboard
How can I know the version type or model name of my Amptron mothe
Look for some numbers in a line, then will tell you the model number of your motherboard
May 29, 2010 | Computers & Internet
Maximum capacity of RAM DDR2 can be installed at Amptron 945 LM4
cos actak sa3a wa adwr 3leha y5jkj ikjkadfji jl kalsfjdsa jasdshgsauy uashgdfsafahasd
Apr 08, 2009 | Amptron PM-9100A Motherboard
Amptron monitor driver
I don't think this monitor needs a driver for WinXp.
Check out: http://tekgems.com/Products/et-26521-mon-amv19wa.htm
All I see is a cd with a user guide.
Mar 17, 2009 | Amptron amv MW9BBK Monitor
Manual for Amptron Motherboard
Hi
I have some information for you. Follow this link for info on this motherboard:
http://www.motherboards.org/mobot/motherboards_d/Amptron/K7-810LM/
Go down the list for various information.
Hope this is of some help. Please don't forget to Rate my solution.
Thank you.
Feb 23, 2009 | Computers & Internet
Identifing a socket a amptron mobo
My Amptron board has the number on the underside of the board. I bet your's will be there as well. I HOPE you paid attention to the front panel hook up ( I could use this info). You cannot find the info on the web.
Regards
Trap
Can you give me the front panel pin setup PLZ?
T
Oct 02, 2008 | Amptron PM-9100A Motherboard
Amptron motherboard
Hi...
Although there is a huge list, I have found a place where there IS a manual for that specific MB
http://www.motherboard.cz/map.htm
Let me know if this helps
~~Jasta~~
Sep 29, 2008 | Amptron PM-9100A Motherboard
No sound from Amptron M930LR Motherboard
check the wiring....there are 3 ports(line in, mic, speaker)..speakers wire should go into speaker port. also check power of speakers is on/off.
Oct 09, 2007 | Amptron PM-9100A Motherboard
Computers & Internet Logo
150 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
