Question about Smeg 24 in. DWD612SS Built-in Dishwasher
Smeg dishwasher DWD612SS Fault
Anomaly in the system which distributes water
  • Smeg Master
  • 19,396 Answers
Chec k if orifices in the spray arms are clogged, if lines are free and it is not sprayiong water, then yopu may need to check water lines and to replace the impeller pump.
Posted on Jan 25, 2009
Error 8 light on. I think all lights flash, then far right light stays on. Recently had issues with it. Not emptying properly. How do I fix it??
6. Troubleshooting
In case of a malfunction, the dishwasher will identify the program by switching on a combination of lights.
When an alrm is present, all the PROGRAMS lights (4) come on, while the PROGRAM PHASES lights (7) identify the error code:
E2
The system which limits the water level inside the dishwasher (safety unit) has been tripped.
E3
The appliance is not able to pump out the water.
E4
Temperature sensor disconnected.
E5
The appliance is not able to take in water.
E6
The appliance is not able to pump out the water from the tank.
E7
The appliance is not able to measure the amount of water loaded accurately (on models with turbine flow-regulator only).
E8
Anomaly in the system which distributes water to the basket (where installed).
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
The anti-flooding system (if installed) has been tripped.
The maximum level of water for loading has been exceeded (on models
Jun 02, 2015 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error 8 . How do I rectify it?
6. Troubleshooting
E2
E3
E4
E5
E6
E7
E8
56
CODE
E9
PHASES LIGHTS
DESCRIPTION
E1
Thjere is something wrong with the distribution. Check for blockages.
Dishwasher cavitates. I have a Smeg DI612CA9
Does the drain hose loop up to the top of the unit before going to the sink drain? If it goes down first it may be siphoning or draining by gravity.
Aug 08, 2013 | Smeg Dishwashers
Hi, Every 2nd time I use my DWD612SS dishwasher the code E8 comes up - (anomaly in the system which distributes water to the basket). How can I fix this. Thanks
E8 - Defective alternate valve functioning
This alarm is generated when the programme starts and the timer card does not detect the signal
that the alternate valve is positioned.
This defect can be caused by:
- defective alternate valve
- electric connections are not properly positioned
- defective electric card
May 30, 2011 | Smeg 24 in. DWD612SS Built-in Dishwasher
Cloudy dishes and hard water
You need to use a product called Lemi Shine. It works amazingly well. You can get it at your local grocery store.
Jun 21, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
Dishwasher has a overfill problem rinse light flashing
An Idea: the Overflow sensor or float is bad, stuck, disconnected and its messages to STOP filling aren't getting thru to the CPU
This is usually located in the right frony of the machine or in the side wall. Float types get gummed up with 1/2 dissolved soap powder (god what we do tho the water systems) see if it moves. Sensor types have a hole that feels or senses water. If clogged, they lie. Clean out with toothpick and blast with a bit of hot water and air. Retry
If fixed, let me know... if not, see the yellow pages for parts dealers ;-)
Cheers
Mar 26, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
Dishwasher not working
try this first is there still water in dishwasher if so your water pump is blocked or failed.
second check your tap connection has it got a flood lock device fitted to hose if so will have to replace hose.if none of these help you may need to replace pcb in extreme cases.
hope this helps.
Jan 07, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
Dishwasher does not complete the cycle
Repair guy came out and after an hour of taking things to bits and not finding a leak , we managed to identify the problem as originating from a faulty door seal at the top door lock ( it was ever so slightly dented in/warped) which had caused the water to track through the door lock down into the machine and trip the electrics after 30 minutes in the cycle. He'd never heard of this happening before - just my luck!!
Door seal replaced and ( so far) everything working fine.
Dec 30, 2008 | Smeg 24 in. DWD612SS Built-in Dishwasher
Hi our dw 1612 integral dishwasher has thrown a fault code E2 which according to the book is a tripping of the water level switch. unfortunately the book dosent tell you where the switch is located or how...
I don't mean to make you sound stupid but it isnt a switch that you can use.
It is used in a dishwaher to make sure that the water doesnt over fill and spill over out of the dishwasher and electricute someone. it cuts off the water (when working corectly) and washes as normal or if it over fills it tells you and in your case it is error E2
you need to speak to a appliance repare shop to see what needs to be fixed or replaced.
Hopefully this has givin you some help
if you have any questions plese dont hesitate to ask
Dec 02, 2008 | Smeg 24 in. DWD612SS Built-in Dishwasher
E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Nov 20, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Smeg 24 in. DWD612SS Built-in Dishwasher Logo
288 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
