Question about NEC HT410 Multimedia Projector
LAMP not switching on NEC HT410
My Lamp not switching on Status light flashing red power light orange, the lamp lights stays off. I have tested everything fans are working and LAMP is secure,
I had the exact same problem and solved it. After calling NEC tech and getting no help, my son and I decided to:
  • Remove, clean and reset lamp.
  • Completely clean (with compressed air) system.
And it worked. Here's what we did.
  • Removed lamp and cleaned with compressed air (in cans).
  • Used two cans of air to completely remove all internal dust. In our case long over due.
  • Reinstalled lamp and reset meter. (To reset: Turn on machine, wait 2 minutes or so, then hold down the "Help" button right next to the infrared sensor on the front of the machine).
Works fine now! Dont know if it was technical solution but solved it for us! Good Luck!
Posted on May 18, 2009
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
Nec lt81 dlp projector
PLEASE SEE THE SPECS OF OLD LAMP AND NEW ONCE ARE THE SAME IF YES TRY CHECK THE POWER SUPPLY AND RATING OF THE SUPPLY. AND RESET SWITCH WITH REMOTE CONTROL
Feb 24, 2008 | NEC MultiSync MT1050 Multimedia Projector
My NEC vt 595 was working fine last night and today i went to turn it on the status and power light started flashing red and orange and there is no picture
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
Mar 18, 2011 | NEC VT595 LCD Projector
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
Turn on the projector the power light flashes green with status as green then it goes to a flashing orange light
there should be a status for the lamp light; check to see if this one turns red. If it does count the consecutive blinks if it is 6 then replace the lamp
Apr 15, 2010 | NEC VT800 LCD Projector
Hi I am having trouble with an LT180 DLP I'm getting a series of error messages culminating in the power light steady orange and the status light flashing a series of 6 flashes red. Inside I found that...
both lights flashing green indicate the projector lost power while it was running (didn't get to go through shutdown procedure). if the status light blinks 6 times, the lamp is failing to strike (one time means the cover is open, 2 times is a temperature issue, and 4 times is the fan). if it comes on and shuts off a short time later (less than 15 seconds), the ballast is going bad and needs replacing. if it didn't come on at all, it'd be either the ballast or the colorwheel. if the lamp light was red, it would be the lamp that needs replacing. nec won't sell parts to anyone who is not an authorized nec service center, so you'd need to contact one to get the part (although they may not sell it to you). but good luck!
Aug 20, 2009 | NEC LT180 DLP Projector
No projection
This sounds like the lamp has not fired. Try a new lamp. If that fails to resolve hte problem, the ballast is the next assembly to be replaced.
Dan
May 12, 2008 | NEC HT410 Multimedia Projector
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
NEC MT820 Projector
Press and hold the power button on the remote control for 10 seconds.
Sep 07, 2007 | NEC (MTLAMP820/1020) Projector Lamp for...
NEC HT410 Multimedia Projector Logo
327 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
