Question about Hotpoint Ultima WF865 Front Load Washer
Indesit iwe 81282 error f05 - Hotpoint Ultima WF865 Front Load Washer
Error code f-05 on idesit wixe127
F05: Pump Blocked or pressure switch empty not reached
- Check efficiency of J9 connector on card, verifying a voltage of 220V between pins 8 and 9
- Check that pump if being fed
- Check Pump Filter + wall drain
- Change Pump
- Replace Card
Dado
Feb 28, 2015 | Indesit Washing Machines
Indesit pwe 8148 w with error code FO5 Is the problem usually either a blockage or the pressure switch? I am going to try to fix it myself but how do i get to the pressure switch to see if it is stuck on...
Hi.
F05 means that the pressure switch shows full all the time:
F05 - Pressure switch jammed on full
The fault is usually fixed repairing or replacing the pressure switch. Before replacing the switch check for draining issues that can trigger F05 and clean the hose connected to the PS. The PS is located inside the appliance in the control panel or at the right side of the cabinet. The part is reached removing the screws holding the top and lifting the top. Power must be disconnected before starting.
Here how the switch looks like:
Sep 14, 2011 | Indesit W 123 Front Load Washer
Code F-05 showing on INDESIT WIXE 127 washing machine. Not emptying or spinning.
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Jan 03, 2011 | Washing Machines
F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Indesit W 123 Front Load Washer
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Locate and remove large black fastened to bottom of drum.
Hop[e this helps you.
Dec 28, 2009 | Washing Machines
Fault f05
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
Nov 24, 2008 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Error code on washing machie
The wording of the error code explanation suggests the pressure switch clicked on to register a water level, but when the water was drained away it remained on instead of turning off. I would guess there could be a blockage in the pressure system, or the pressure switch could be faulty. Also, if the water didn't drain properly it would cause the pressure switch to stay on too.
Jan 03, 2008 | Indesit W 123 Front Load Washer
Indesit we14
Hi l have a indesir WIE147 that keeps on flashing F 01 repair man came changed module and next day same thing happened again HELP PLEASE
Nov 13, 2007 | Indesit W 123 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
95 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
