Question about LG Computers & Internet
Download driver for lg l1720b to ubuntu - LG Computers & Internet
L1720b monitor pop-up
You need to enable the pop up blocker in your web browser.
May 15, 2014 | LG Computers & Internet
GSA-E60N need driver for ubuntu linux
No driver required. Linux will use a built in universal driver.
Apr 16, 2014 | LG GSA-T20N DVD±RW Dual Layer Burner
I need scsii driver for IBM X346 for UBUNTU
Hello you can try to download the drivers from here:
http://www-947.ibm.com/support/entry/portal/sdd?key=5178881&osKey=null#5282380
Do you have the latest version of ubuntu if not download here:
http://www.ubuntu.com/download/server
Try the 32 bit version.
Try also the ubuntu forum:
http://ubuntuforums.org/forumdisplay.php?s=45713461a2219625389237c1c60ec045&f=130
Good luck
Oct 27, 2012 | IBM eServer xSeries 346
How to reset factory setting of monitor lg l1720B
Sounds to me like the button is stuck with pressure on the sensor. try moving button around a bit if it is a flat surface button then the surface is likely distorted and wont release it would have to be replaced at that point.
Sep 06, 2012 | LG L1720B 17" LCD Monitor
LG L1720B 17 inch LCD Monitor NOT POWER ON . I CONECTED THIS CABLE BUT SWITCH ON BUT MONITER NOT ON
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 19, 2010 | LG L1720B 17" LCD Monitor
Hi. Update drivers for Ubuntu?
There's probably no need as long as the aspect ratio is set to your liking:
System > Preferences > Display
However, if you need a better experience in Ubuntu, you might consider looking into your video card. There are some proprietary drivers out there, notably Nvidia, which are also free to download and use, though you'll never get the source code.
Apr 04, 2010 | LG Flatron L1750S 17" LCD Monitor
Ubuntu Video Driver repair
Go to system > Admin > Restricted Driver Manager.
Enter your Admin password.
Two things might happen now either ubuntu will download the drivers it needs or it will provide you with a list of the drivers on your computer allowing you to choose one.
Enjoy your stay in ubuntu land.
Aug 12, 2008 | Canonical Ltd. Ubuntu
Drivers
In the menu of the phone, select Phone Setting, then Connectivity, then you will be able to see "USB connection mode" menu. If you select "Mass storage" in this menu, your phone will react as a normal USB key drive on your system.
It worked for my XP, or Ubuntu machine.
Otherwise, if you select "Data service" in the USB connection mode, you need LG PCsuite software installed to be able to communicate with it. This PCsuite is downloadable in LG web site.
Mar 05, 2008 | LG KU990 Viewty
Computers & Internet Logo
21 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
