Sharp AR-5420 how to find the fusing unit to reset thrmo breaker
  • 126 Answers
SOURCE: Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Posted on Feb 01, 2009
SOURCE: Sharp AR-162 Laser Unit
searching for solve problem L6 error in the machine sharp m 160
Posted on Mar 19, 2009
  • 32 Answers
SOURCE: Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Posted on Apr 17, 2010
  • 3 Answers
SOURCE: IS there a reset code for a Sharp AR-507 copier,
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
Posted on May 18, 2010
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Posted on Jul 17, 2010
What to do when Sharp AR-M205 showing message h4
Fusing error.
check fuser unit first and reset by simulation 14.
Mar 11, 2014 | Sharp AR-M205 Copier
Problem for Sharp AR-5320
The Fault fuzer. Possible faults of the block of the fastening the scene or in contact of the join or in signal of the controller of the direct current.
Address please in service Sharp
H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error
Oct 08, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-153E error code H 4
heat roller in fusing unit problem. lamp,fuse,thermostat, or thermistor bad. Try reset first
Jul 12, 2009 | Sharp AR-153E Copier
On my Sharp ar-c160 copier, where is the fusing unit thermal breaker?
its on the motherboard i believe, I used to repair copiers as a tech in the late 1980's
Jul 11, 2009 | Sharp AR-C160 Color Copier
Problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Jun 04, 2009 | Sharp AR-M237 Copier
Sharp Fuser
Feb 01, 2009 | Office Equipment & Supplies
SHARP AR163 Displaying H2 error code
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Jul 26, 2008 | Sharp AR-C160 Color Copier
H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Dec 31, 2007 | Sharp AR-5320 Black and White Copier
189 people viewed this question
k24674
jasbo
jasbo
